SPN 4374 FMI 14 code on a 2017 Cascadia with DD15
Discussion in 'Freightliner Forum' started by AlexD13, Sep 8, 2021.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hello everyone, wondering if anyone has gotten this code or has an idea what it can be? SPN 4374 FMI 14. I have a 2017 Cascadia DD15 with 600k miles
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    9 times out of 10 it is a failed DEF pump. Before you replace remove and inspect/replace DEF pump filter.
    AlexD13 Thanks this.
  4. AlexD13
    298
    85
    Jun 13, 2016
    Should I change the lines as well if it is the Pump?
  5. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Here's the diagnostic steps for the fault.
    Vitkouski and QUALITYTRUCK Thank this.
  6. Ross_Tech
    Ross_Tech Light Load Member
    133
    133
    Aug 31, 2021
    Before you condemn the pump, check the pressure at the doser with a manual gauge. The pressure sensor is in the doser, and I've seen a truck where techs changed the pump twice, only to find out the sensor in the doser failed.
    Vitkouski, AlexD13 and QUALITYTRUCK Thank this.
  7. AlexD13
    298
    85
    Jun 13, 2016
    Mechanic so far said there is an Air leak causing this , he wanted to fix that before changing a pump
  8. ABiceRoads
    ABiceRoads Bobtail Member
    7
    Apr 30, 2018
    Mine is leaking from the fitting where it connects to the def pump. I found a small clamp on this fitting is broken and loosing def pressure. Code I got is SPN 4374 FMI 14. My question is Can I just replace small plastic clamp on this fitting to stop the leak or do I have to replace the hole heater line?
    Any suggestion will be greatly appreciated.
  9. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Unfortunately you need to replace the heater line.
    ABiceRoads Thanks this.
