SPN 4364 FMI 31 Doser module.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Jul 25, 2023.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    I got this code SPN 4364 FMI 31 , I guess Doser module. So, how many more miles can I drive and can I replace it myself. Cummings engine.
  3. Judge
    84,432
    Oxbow Thanks this.
  4. Ikamob01
    314
    195
    Dec 4, 2021
  5. FLFrenchie
    FLFrenchie Light Load Member
    50
    33
    Sep 11, 2009
    I’ve got a similar code on Pete 2017- also derate at 4 hours. My experience says it could be bad DEF, or clogged doser or def filter. An obstruction in the lines is possible. I am going to start with emptying def tank and replacing with some fresh fluid. Cheapest fix. What reset tool are you using?
  6. Ikamob01
    314
    195
    Dec 4, 2021
    Otr
  7. Ikamob01
    314
    195
    Dec 4, 2021
    I will start from the filter.
  8. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
  9. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    ###### emissions problems will be the death of you. If you've got the cash you might consider what I did. I was having emissions problems left and right so I had the filter replaced (not cleaned) and all the sensors changed while they had it off. Also the 7th injector. The only 2 sensors I didn't have replaced were the nox because I had already had one done a couple months earlier and the other was like $500. Anyways, since I shelled out the cash to have all that done I've gone well over a year now without any emissions related problems.
    It's a lot up front but everything is so much more expensive on the road and why deal with the constant aggravation.
    Siinman Thanks this.
  10. Ikamob01
    314
    195
    Dec 4, 2021
    I replaced the filter, it stopped for a while then poped up again. i will try and replace the doser this weekend and see what happens. is it plug-and-play. I have OTR reset tool.
  11. FLFrenchie
    50
    33
    Sep 11, 2009
    Ok sounds like a plan. Doser is often a culprit. I think my issue is that the def pump is either leaking or def lines to doser have crystallized or are leaking- so a blockage or not enough suction to get def fluid to doser. I have a different SPN number than you but still a derate situation
