Spn 2659 fmi 18 HELP!! Im on the road
Discussion in 'Volvo Forum' started by Movingismylifeilovemoving, Sep 5, 2016.
  1. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    So Im 1500 miles from home and get this code today. From what Ive read it sounds like a plugged egr cooler?
    Couple questions
    Can I drive it home like this to get ot fixed at my usual shop?
    Is there anything I can do myself to fox this?
    And can amybody recommend a good shop in houston,tx? I try to stay away from the dealership.
    Thanks for all the info
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Which motor do you have? Usually if a red check engine light comes on it will dearth the motor quickly might be best to check it out
  4. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
  5. Sharky88
    715
    851
    Sep 25, 2013
    What do you mean making oil? What color is the oil? Is it grayish? Thick?
  6. Sharky88
    715
    851
    Sep 25, 2013
    Your egr valve is either stuck or clogged. You will need to replace it soon.
  7. Vadimg12
    Vadimg12 Bobtail Member
    6
    5
    Jul 6, 2017
    Have you fix ur truck ? What was the problem?
  8. Vadimg12
    6
    5
    Jul 6, 2017
    What was ur problem??? How did u fit it?
  9. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
    I took it to the Volvo dealer in Houston and they reflashed the ecm with updated software. However, in March the egr valve, cooler, and manifold needed to be replaced.
    They also said the exaust valves are recessed by .06 and that the head needed replaced.
    Do you have any info on recessed valves? Thanks
  10. Vadimg12
    6
    5
    Jul 6, 2017
    I just replace head on my 2013 Volvo with d13. I did in local shop. Cylinder head I found for $2500.00 with 1 year warranty. There is one Compony in IN state. You can find them on eBay.
    Reason why I change cylinder head cuz my exhaust valve broke and I had no compression in cylinder #5.
    My recommendation before do something you need compression test.
    replace m
