Splitter buttons
Discussion in 'Experienced Truckers' Advice' started by okiedokie, Jul 4, 2011.
  1. okiedokie
    okiedokie Road Train Member
    12,277
    91,545
    Jun 13, 2011
    PNWET
    What are the colors of splitter buttons and types of trans they are on ?
    Are there any trans that have a Reverse besides in the H pattern?
    Are there any trans that have a different shift pattern than a typical progressive H pattern?
  3. davenjeip
    davenjeip Medium Load Member
    459
    257
    Dec 20, 2009
    Port Charlotte, Fl
    Think that every splitter button I have used has been red.
    15 speed I used to drive used a U pattern instead of an H.
    Also drove this really odd 10 speed in a straight truck. Pretty much a 5 speed where you split the gears, like a Super10. Odd thing is that you would run 1-3 splitting the gears, then go 4lo to 5lo, then back to 4hi and finish up in 5hi. Only figured it out after reading the sticker on the sunvisor, and still can't fully understand how it works.
  4. Poobah
    Poobah Light Load Member
    233
    156
    Jun 23, 2009
    Arizona
    On the Eaton transmissions:
    13 speed=red splitter button,
    18 speed=grey " ".
    okiedokie and johnday Thank this.
  5. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    blue on a 15 speed i drove
    okiedokie Thanks this.
  6. james3505
    james3505 Light Load Member
    82
    29
    Jan 21, 2010
    ozark,ar
    blue on the 8LL and 15
    red on 13 speed
    grey on 18 spd
    i think the super 10 is grey also
    you can turn the last two holes around fo overdrive and it shifts in a u shape for the most part
    Flying Dutchman and okiedokie Thank this.
  7. okiedokie
    12,277
    91,545
    Jun 13, 2011
    PNWET
    winner winner chicken dinner james. how about the reverse not in the H pattern?
  8. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    That was 2 speed rear was it not?
  9. jbatmick
    jbatmick Road Train Member
    2,197
    2,501
    Dec 1, 2009
    hastings, Fl
    I had a single axle truck like that. It was a 2 speed rear end.
  10. sidepocket
    sidepocket Light Load Member
    268
    88
    Mar 1, 2011
    louisa, va
    some macks still have a reverse that is basically the forward gears with a deep reduction...
    my old 3 stick mack had 6 or 7 reverse gears...actually pretty useful
  11. okiedokie
    12,277
    91,545
    Jun 13, 2011
    PNWET
    yepper it was a Mack trans that had Reverse on the splitter. Ran a Mack dump truck pioneering logging roads w/ a triplex(3 stick) trans. Lots of guys w/ extensive experience on this board.
