Split Axle Weight on a 5 Axle?.... Why?
Discussion in 'Experienced Truckers' Advice' started by Grumppy, May 10, 2015.
  1. Grumppy
    3,051
    10,341
    Dec 11, 2010
    West Monroe, La
    Ok, I pull up to the scale at a Loves the other day & a Melton flatbed was just pulling on the scale. I waited.... & waited... & waited... for at least 5 minutes. So, I pick up the mic & ask the Melton driver; "They not answering the scale in there?".
    No answer.
    So, I wait.... & I wait. For maybe a couple of more minutes. So I ask again; Melton, they not answering the scale?
    No answer.
    I wait maybe another minute & I get out & walk up to his truck thinking; well, maybe he pulled on the scale & died. There he was up in there & was just about to pull forward when I asked him; they not answering the scale in there? He said, yeah, but I need to get a split axle weigh." I'm thinking, uh you do know that these cat scales will weight a 5 axle truck on one weight right? But, I didn't say anything, I figured he knew something I didn't know. So, I watched him pull up just enough that his steers & the front drives (not the rear drives, just the front) were off the scale. The rear drives & the trailer axles were still on the scale.
    I'm totally confused.
    So, when I went inside to get my scale ticket, this driver was in there getting his scale ticket. He looked over both scale tickets & kinda gave a disgusted laugh & said something I didn't quite hear. Again, I left it alone but was awfully curious.
    When he walked out I asked the lady at the fuel desk what the deal was with this guy. She said he needed a split axle weight. She didn't know how to do that so the hold up was trying to get a manager that knew how to do this. She added that after all that, he weighed more on his 2nd weigh than on his first, so he was disgusted. (Huh?) He didn't understand how he could weigh more on the 2nd ticket than the first. (When I left after a while, he was out on the phone talking to someone... about his weight I guess)
    I thought to myself, I don't understand any of this. It was just a 3 axle (steers & drives) truck & flatbed (2 axle) with something under a tarp right in the center of his trailer.
    Why would he need to scale split axle when the scale weighs each "set" of axles & why would he scale with only one set of drives & both trailer axles on the scale? (Note: the only scale he got was the above mentioned split & entire tractor/trailer weight... no other weight)
  3. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    The only time you have to worry about one drive axle being different than the other on a normal over the road tractor, is when the suspension is bound up and broke. Just let it go as something that "guy" wanted to do on the scale. Nothing more.
  4. Ridgeline
    22,108
    113,242
    I've done this before, one of the trucks I drive is setup rather dumb and to get each axle weight, I have to move the truck on the scale because of the scale itself. The truck has 6 axles grouped like this front steers, mid pair and rear three. I can't with that truck get axle weights pulling up on the scales.
    KANSAS TRANSIT Thanks this.
  5. IH Truck Guy
    4,119
    46,694
    Mar 2, 2008
    Purgatory
    Was it a spread axle flatbed?????
    If so,he was split weighing the spread.... My guess..
  6. Grumppy
    3,051
    10,341
    Dec 11, 2010
    West Monroe, La
    It wasnt a spread axle... I don't think. I didn't notice it being a spread axle. But he wasn't just weighing the trailer axles. He was weighing one drive & both trailer axles.
    Just to add as well, I do have a couple of customers that I go to that have either just one, small scale or one long scale that doesn't weigh each axle, so I do understand sometimes in those situations you/I need to weigh each axle but that wasn't even close to what this guy was doing.
    Further, one the face, I have no idea what his intent was but, that doesn't mean anything cause I am not that experienced in that sorta stuff, so I understand, like I said in the OP, he's gotta know something I don't but, Its awfully curious to me.
  7. IH Truck Guy
    4,119
    46,694
    Mar 2, 2008
    Purgatory
    He was doing 2 split weighs at once,if I'm thinking right.
    If he only had one drive on the scale,he already had the weight of the 2 drives if he already scaled the normal way.
    Just subtract one from the two.
    I have to bet it was a spread axle trailer,because the front axle would have been on the drives scale and the back axle would have been on the trailer scale.
    He would have ended up with 5 seperate axle weights doing 2 weighs.
    Grumppy Thanks this.
  8. passingthru69
    Well Ga. has been getting testy here lately on I16 about weights not being even. Just because you have 34 on a tandem does not mean an even split. If over 17 on your axle you might be getting a ticket.Yes their scales are setup to weigh each axle
  9. IH Truck Guy
    4,119
    46,694
    Mar 2, 2008
    Purgatory
    Land of Lincoln is the same way..
  10. MACK E-6
    48,120
    219,562
    One of those trailers with one sliding axle, that can run as a tandem or a spread perhaps?
  11. passingthru69
    It's really hard telling what that driver was doing, and yes when you tell some of the people you want a split weigh they panic..
