Spindle nut socket size
Discussion in 'Trucks [ Eighteen Wheelers ]' started by redgod7, Oct 6, 2016.
  1. redgod7
    redgod7 Light Load Member
    67
    41
    May 18, 2013
    Detroit, MI
    Anybody know by any chance the spindle nut socket size for the steer axle on a 2007 W900. They're ConMet preset hubs on there. I would like to buy the socket beforehand. Dont like to take it half way apart and then trying to chase a socket. For my drives it was a 4" so has to be smaller for steer.
    Also when I did my drives I torqued nuts down to 300ft-lbs inner 200ft-lbs outer as per spec. Do you guys do them the same way? I heard mechanics say that they still back them off some even tho they're preset. Hub temps been running around 110-120F since it did them and I've put some miles on them so far so good. Can't find a temp spec and ConMet says they can run as hot as 150F above ambient.
  3. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Im thinking 2-1/4. I got conmets on my kw and thats what mine is.
    SAR and redgod7 Thank this.
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    BoxCarKidd Thanks this.
  5. redgod7
    67
    41
    May 18, 2013
    Detroit, MI
    Yes I did follow the instructions and I got the torque specs from their website. I feel like a lot of mechanics are afraid to get these bearings tight. The spindle nuts came off pretty easy which means last guy who worked on it set them hand tight. Would explain why seals lasted only one year. :mad:
  6. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Only reuse the spacer on a conmet hub if you reuse the bearings. NEVER reuse that bearing spacer on new bearings.
    Honestly, those spacers wear over time causing it to loose clearance. I dont like reusing them. I leave them out and set bearings the old way with dial indicator or basically zero to SLIGHT preload.
    SAR, Oscar the KW, Oxbow and 2 others Thank this.
  7. redgod7
    67
    41
    May 18, 2013
    Detroit, MI
    Yea I thought about leaving them out but i couldn't see anything wrong with them. To be on the safe side I've been monitoring the hub temp with a temp gun and all seems normal as far as I can tell. How hot do your hubs run the way you set them I am curious.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Bearing clearance specs of .001-.006. Can you see that even though you can see the moon and how far is that?
    Bearings to tight will tend to generate heat while loose bearings will tend to cause a seal failure.
    Sorry I cannot answer you normal temp question but it is highly effected by the brakes and vehicle usage.
    Would be more concerned about one running much higher than the others or anything over about 250 degrees.
    Infrared temp guns are cool but there are other indicators.
    Burnt rubber smell: May be caused by heat from a low pressure tire. A rotten or separated tire about to give up. A brake dragging transferring heat to tire.
    Burnt oil smell: Could be a leaking wheel seal or a bearing problem anywhere from the hub to the driveshaft.
    When running heavy and or before going into an area without services for a long time I always stop and look things over. Touch the tires and hubs while fueling or just do a pretrip in the middle of the trip.
    Yes you can get odd looks from the "It blows smoke and the wheels roll pretrip guys. Wave when you go by.
    SAR and snowman_w900 Thank this.
  9. Antonio_379
    Antonio_379 Bobtail Member
    By any chance anyone know the spindle nut socket size i need for my front steer 1996 peterbilt 379? I believe theres 2 different sizes of spindle nuts.
