I have a spicer 10 speed transmission. All the gears work fine except low reverse. Anybody know what my problem could be?
Spicer transmission trouble
Discussion in 'Experienced Truckers' Advice' started by Cltrucking, Mar 23, 2018.
Page 1 of 3
How is low reverse not working? Won't go into gear? Truck won't move? We need more to go on, please.
Like its not going all the way in gear its grinding when you put it in low reverse and release the clutch
Hmmm....when was the last time you had the clutch brake looked at?
If I remember correctly (haven't seen a Spicer in over a decade), those were amazingly unforgiving transmissions. You had to have everything lined up just right for the gears to mesh properly.
Another possible issue could be simple age and wear and tear. Again, working on faulty memory, I don't recall Spicers being a very popular transmission even in their heyday. As I said, not a very forgiving transmission. I do remember hearing mechanics complain about them, but it was mostly concerning driver abuse. The Eaton Road Rangers were preferred because newer drivers (such as meself at the time) didn't tear up the Eatons as quickly.MACK E-6 Thanks this. -
New collar new range fork kit new range synchronizer new clutch gear new throw out bearing new brake clutch. Ran the truck 9 days after a shop replaced all this
Then somebody screwed up something in installation. Was the work warranties?
Justrucking2 Thanks this. -
01 international m11
I bought the truck from a blueberry farmer that only run it during blue berry season. They done all that to the truck 7-7-17 and he didn't run the truck after until I picked it up 3 weeks ago and the shop is supposed to call me to set something up but they are just dragging it out and I can't wait around on em
It does sound like the clutch brake, I wonder if that was a problem before it was worked on.
Page 1 of 3
