Speedo is slow 1-2 mph. Odometer shows close to 5% more miles. Are they related? My drive tires are pretty low. I know it affects it some. How are they calibrated? Its on Volvo with Cummins and Fuller
speedometer and odometer off
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Jul 20, 2015.
At an average speed of 50mph, a 2mph error is 4% Along with tire wear, etc. Probably all related.
My new T680 came with steer tires on all 10 positions. We took them off the drives and put on lugs which are quite a bit larger diameter than the tires that came on it. The result, at 70 mph indicated I was running 73 per calibrated GPS. For every 100 miles I drove per the odometer I actually traveled 105 or 5% more so the odometer and speedometer were both slow (again checked against an aircraft calibrated GPS system). I just went in Saturday morning and changed the RPM in the ABS system for the drives (which also stopped the random ABS light when turning right) because this truck uses the signal from the left rear ABS tone ring for the speedometer/odometer. I reset the trip in my GPS and checked it against the odometer coming to where I'm at now and for 208.8 miles I had a difference of 1/10 of a mile between the odo and GPS. Speed was exactly matched on both.
If you have a speedometer reading slow and an odometer reading fast then you have much bigger problems than tire sizes. -
I have a 2007 volvo vn. My odometer says I'm going 85 while a GPS says I'm only doing 69 yes truck is governed. I changed the transmission speed sensor and it still does the same. Also my mileage is way off. When I travel a certain highway i know for fact is 250 miles from state line to Stateline. It is actually saying I've done 305 miles. That's 55 miles over. What else could be the problem. Please help !!!!!!
Big Road Skateboard Thanks this.
