Greetings, I'm having problems with the speed sensor on the output shaft of my Eaton Autoshift transmission. The one that's there was forced threaded in the hole and wont stay tight, and the hole is not threaded. The replacement sensor i purchased is the non-threaded type, and seems to be to large for the hole.There are three possible sensor mounting locations on the shaft; 12 o'clock, 9 o'clock, and 6 o'clock. A tech at the Volvo shop told me to just use another hole, but I'm not sure how to remove the plugs or even if the space is availabe for a sensor. Can someone look at the pictures and tell me if you think it's possible, and how to removed the plugs? Thanks![]()
Speed sensor problem on Eaton Autoshift transmission
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Apr 4, 2019.
The hole where your existing sensor is should have a bolt next to it like the others. The correct sensor should push in the hole and just be held in by the correct bolt. No adjustment required.
silver dollar Thanks this. -
Make sure the hole is not buggered up and is clean. Use some oil on it and a little pressure.
Change all of them and the 2 rail sensors while you are down there harness to.
I changed the speed sensors and then had the rail sensor go out shortly aftersilver dollar Thanks this. -
The holes in the tail housing get filled with rust. The sensors gets rust jacked and break as they are plastic. The new style Eaton sensor part number is recessed and has cutouts to prevent this. The gooves in the sensor leaves more of a gap between the sensor and the housing.
Quit goofing around.......order a seal kit and a nut. Pull the housing off the truck. Break out the sensors and clean the bores out with a carbide burr bit and reassemble. The sensor comes with copper antisieze to coat the hole and new holdown bolts.
The main shaft and input shaft speed sensors have the same issue and are in the shift bar housing. Those you can do from the top without pulling anything apart. Just have take the old sensors out in pieces.2013Maxx and silver dollar Thank this. -
Well, I was under the truck to day and following a tip from a driver, I discovered that the speed rotor, (tone ring) is not tight on the shaft. I can insert a screwdriver in the hole and move the ring on the shaft. Even though the sensor is not the correct one, its not the problem.
Question: What keeps the ring tight on the shaft? And If I do this job myself, who would most likely stock the parts? ie: Fleet Pride, truck dealers, etc. Thanks again. -
The yoke is loose. Pre- load from the yoke and bearings hold the tone ring tight. Get a seal kit and a yoke nut and the correct sensor and dont forget strap kits for the u-joints. You will need a big gun to get the yoke tight.
You are correct with this being your issue for dropout. Quite common. Any truck dealers that have Eaton products in their trucks should stock these parts.silver dollar Thanks this. -
Is Eaton still putting a slight twist in the spines to lock the output on? It's been a while since I pulled on off, but none would come off without a puller and many had to be cut off with a torch.
