I continue to get Speed sensor failure messages on my QC Omnitracs. It's not pulling the speed or the miles for the ELD. I have to make the changes to my status manually. The company that installed the unit can't figure out why it's not working. They told me to take it to Freightliner. I have a cat 3126b. That motor has two speed sensors. It can run on just one sensor. Wouldn't make sense that the issue is one of those speed sensors have failed? I am at a loss right now.
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by TA1199, Dec 16, 2017.
Page 1 of 3
The speed sensor is on the transmission, not the engine. Normally you'll see an erratic speedometer as the first symptom of impending speed sensor failure. But that's likely not the problem.
I'm not familiar with QC, but the ELDs (but not AOBRs) must interface with the ECM per the regs, and all of them that I've researched do that through the J1939 bus. See if there's a diagnostic screen on your QC, and see what it shows for the J1939 status. It might even show the values received from the ECM.
Since your not getting miles or odometer, my guess is you're not getting a link to the bus. A few of our Western Stars required a different harness with a couple pigtails to splice into bus somewhere other than the diagnostic plug. The bus is easy to find, it's normally a green and yellow pair of wires.Jazz1 Thanks this. -
It shows speed sensor fault. Odd thing that happened after it was installed was the cruise control stopped working too. It doesn't even show up as installed on the truck anymore.
I have found it I manually change it to driving before I take off it doesn't do that. Only seems to happen occasionally when I drive off and it switches to driving on it's own. -
Not sure if this will make a difference or matters but I will add it anyway. My truck was a Canadian truck. The Speedometer and odometer are in Kilometers.
Page 1 of 3
