Specs for a B-Train Hauler?
Discussion in 'Experienced Truckers' Advice' started by beancounter, Jan 28, 2011.
  1. beancounter
    beancounter Light Load Member
    182
    71
    Sep 4, 2009
    Greenville, MI
    This question technically comes from my brother up in MI.
    He has an opportunity to hook up with an outfit hauling lumber on B-Trains, and mostly stays in Michigan. Since you can run over 80k gross with an 8 axle trailer in MI without special permits, he's wondering what sorta specs (tranny, gearing, hp, etc.) would be recommended for heavy haul.
    Any info, especially some of you....um, seasoned vets, would be appreciated. BlackW9 and REDD, that's right, I'm talkin to you. :biggrin_25525:
  3. Martin
    Martin Bobtail Member
    14
    Nov 6, 2007
    Warren, MI
    My 379 Pete has a 3.36 rear, 600 CAT and a 18 speed trans. Loads of 120,000 lbs are no problem at all.
    beancounter Thanks this.
  4. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    i think it is the 18 speed that is helping there--but that would probabely give you the best fuel economy--with a 13 i think somewhere around a 3.70 or 3.90 would be better--but with a 10 spd--i think it would really suck pulling that weight
  5. beancounter
    182
    71
    Sep 4, 2009
    Greenville, MI
    Yeah, I'm sure that would do the trick.:biggrin_25514:
    That's kinda what we were thinkin, at least a 13 speed. So, would it work better like you are showing it (13 speed with 3.90's, and 18 speed with 3.36's)?
  6. YukonTrucker
    YukonTrucker Light Load Member
    203
    51
    Dec 9, 2007
    Whitehorse Yukon
    Go as much hp as you can. 18 speed is my personal preference but I am sure a 13 speed would do alright. As for gear ratio depends on the terrain I have never been to Michigan and probably never will but for the heavy haul I do in northern Canada I have 4.33's but that is probably too low for Michigan.
    Go with heavy rear ends I run 46k lb rear ends the nice thing about heavy rear ends is you know they will hold up to the big loads.
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    You don't need heavy rear suspension for MI because they have light axle weights. But big HP is almost a must.
  8. beancounter
    182
    71
    Sep 4, 2009
    Greenville, MI
    Because the weight is spread over so many axles, right?
    It's not like an RGN where you're haulin heavy, but may only have 2 or 3 axles that are clear to the back of the trailer.
  9. hotrod1018
    hotrod1018 Light Load Member
    81
    31
    Jun 23, 2010
    Niceville fl
    when i was in MI pulling a 6 axle tanker we had cummins 550 13 speed with 4.33s and the 4.33s were overkill your runiing 1750 rpm at 68 mph
  10. canuck in da truck
    4,352
    2,601
    Aug 6, 2010
    western pa
    with super b's we had 13 sp with 3.70 rear end--it seemed pretty good--but then that is all i was used to--so i imagine if you were going thru the rocks a lot--an 18 with 3,90 would be better--but i am not sure how that would work for fuel mileage as for which set up would be better--and this was with turned down detroits-so like the the other guy said the more hp the better
  11. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    Yes, when your over 80k axles spaced 9' apart or more are allowed 18k. Axles spaced more than 3.5' but less than 9' are cut back to 13k but one tandem axle set per truck is alowed 16k (usually the drives). So while your allowed 164k gross on 11 axles, the weights are pretty low.
    Here is a link with the rules.
    Biggest PITA with Michigan is the frost laws. They LOVE to write tickets for being on the wrong roads/streets at the wrong times of the year.
