Spare tire carrier ideas? Flatbed
Discussion in 'Flatbed Trucking Forum' started by blanco, Oct 15, 2012.
  1. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    I've searched briefly for spare tire carriers for flatbed, but no good luck.
    What do you guys run? I want one that will bolt up w/o drilling or welding. Is welding ok?
    I've seen a couple that we've installed on our dry vans and it was drilled and installed. Kinda hard to drill through a thick flatbed frame.
    Ideas please?
    edit. 2008 Utility 48 foot combo
  3. dptrucker
    dptrucker Road Train Member
    4,671
    3,182
    May 14, 2012
    adelanto,ca.
    not totally sure but don,t think you can weld on a frame but i could be wrong
  4. Big_Perv93
    Big_Perv93 Light Load Member
    75
    25
    Jan 8, 2011
    Joplin, MO
    Look in between the frame in front of front trailer tires. My friend carries 3 tires on those 1-1.5 inch metal pieces and uses a shortened 2inch strap for each
  5. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I keep trying to figure this one out also as I have a 53 ft slider spread drop deck and constantly have to move the tire around. I hope someone has some good ideas.
    The Challenger Thanks this.
  6. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    We use a modified winch up carrier off of a military truck
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    The web is thinner than you'd think.
  8. Quickfarms
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Drilling a frame is not that hard if you have the right equipment. The shop uses a bucks drill, it is basically a portable drill press with a magnetic base.
  9. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Spare tires end up getting thrown in the trash, more than they get used.
    SHC Thanks this.
  10. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Why not just go to the Utility dealer and have one installed? They were offered, and they carry them for your trailer.
    I personally wouldn't waste my time with it, as I will only run good name-brand tires anyways. If one blows out, i just have it replaced with a new one. I've had no luck ever with used tires. Unless you are going to carry a jack and impact with you to do the change out on the side of the road yourself, it's just added weight and drag on the underside of your trailer.
    sewerman Thanks this.
  11. Autocar
    3,167
    2,358
    Apr 28, 2012
    My landlord and his partner run a road service business. They see a lot of bad spare tires.
