South Carolina Z restriction on a class A CDL
Discussion in 'Questions From New Drivers' started by truckman29801, May 4, 2013.
  1. truckman29801
    truckman29801 Medium Load Member
    469
    109
    Mar 10, 2013
    SC
    Well i just got my CDL a few weeks ago, i took the test in a FL80 Freightliner single axle truck with a 4 car gooseneck trailer (fifth wheel not a ball). when the license was issued they gave me the Z restriction which they said "because it has a "baby fifth wheel" it needed the Z restriction. Now i have all the insurance i need and i now have the contacts i needed for loads so im ready to go to work. last night i was looking at a TN cdl book just scrolling thru and i came across this "57 - Except Tractor-Trailer - Added to the Class A only, for drivers who operate a vehicle meeting Class A weight definitions, but the power unit alone is also capable of carrying loads. Examples: Dump truck towing a backhoe. Truck towing a mobile home."The Z is Except Tractor-Trailer on my license, i took the test with a truck that cannot carry a load by itself and the trailer was over 10,001 pound. This is what SC says about a Z restriction "For a driver to lift the “Z” restriction, they would need to take any knowledge test as needed and take the complete road test ( pre-trip, basic control skills and road test). The unit must have a fifth-wheel articulation
    and meet the GVWR requirements to lift the “Z” restriction. " I DID THE PRETRIP, THE BASIC SKILLS AND THE ROAD TEST WITH A FIFTHWHEEL THAT HAS ARTICULATION OBVIOUSLY, AND the fifth wheel is rated at 32k pounds. i dont want to go to another state and get jammed at the scale house because of a mistake. What should i do? does this sound right?
  3. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    It seems the same as wanting to get a passenger endorsement...you cannot get it if you test in anything except a bus. A straight truck won't work. Since your trailer was a lighter trailer...maybe if you went back with a heavier trailer?
    I dunno. Seems like a load of crap, but maybe have to go back with a heavier trailer.
  4. truckman29801
    469
    109
    Mar 10, 2013
    SC
    my trailer is weighted at 28k, wayy above the 10,001 pound that makes it a class A truck and my power unit is under 26k and cannot carry a load by itself
  5. Noggin
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Yeah its not making sense the more I think about it. But, the DMV has always been run by morons...lol
    RustyChops41 Thanks this.
  6. truckman29801
    469
    109
    Mar 10, 2013
    SC
    i just dont want these morons to take my license back lol. I need this to drive this truck, i took the test in it and i had to check all 5th wheel parts. So i believe i qualify for the Z restriction to be lifted. To add to that, even if the trailer had electric brakes they told me it would count off if i didnt say Brake chambers/ airlines on the trailer portion. im wondering if i should call the CDL help desk or just go back to the DMV to get toyed with
  7. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    How about just renting a truck for the test that the DMV considers as qualifying?
  8. truckman29801
    469
    109
    Mar 10, 2013
    SC
    because i already have my class A i just want to understand why this restriction is there. I have my Own truck im not going to spend 100s to rent a truck when i already have the equipment right here that i own. I have no "ball and chains" nor the pintle hitch, i have a fifth wheel. thats like saying "your going to get an automatic restriction even though your going to take the test in a stick shift truck".
  9. truckman29801
    469
    109
    Mar 10, 2013
    SC
    i might add my truck is a tractor unit, i cannot carry a load on the truck itself. that makes it a "tractor trailer" combination lol.
  10. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    There is no understanding the government. Your best value in this situation is probably to simply re-take the test with equipment that will get you the class A without the Z restriction.
  11. truckman29801
    469
    109
    Mar 10, 2013
    SC
    but that means using the same type of equipment i already have. you dont think i should call the CDL department?
