sounds of a turbo dying
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Frenzy, Aug 6, 2011.
  1. Frenzy
    Frenzy Medium Load Member
    331
    186
    Mar 24, 2008
    Seattle, WA
    I have a sound that developed today that is like a belt slipping (sorta kinda maybe) except that it is tied to the amount of turbo boost.
    The sound (which sorta sounds like a belt slipping on bad bearings) starts at 10 psi on the manifold guage. I might be seeing a small loss of boost pressure, hard to tell.
    I'm thinking that it is a clamp slipping under pressure and letting some of the boost pressure escape under the flexible pipe, leading to a "kazoo" type of sound. (If you don't know what a Kazoo is, there is no hope for you).
    I have the old turbo sitting next to me. So should I try to figure out if its a clamp, or just change the turbo back?
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    It may be an exhaust leak before the turbo. I would check all the bolts in the exhaust manifold. Its my guess that 1 is broke.
  4. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    What year and motor. My accert cat had the same kinda noise and it was 2 things. 1 some of the exhuast sleeves on the manifold where broken and 2 one of the metel pipes had a crack in it from the turbo.
  5. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    when the new turbo was fitted , were the contact surfaces cleaned and a new gasket installed.
    P.S u can check for leaks by, spraying soapy water onto surfaces. start tuck run at about 1500RPM for say 3 to 5 mins (or get someone to sit in truck and help) to build boost then with engine still running, spray soapy water onto joins etc.
  6. Frenzy
    331
    186
    Mar 24, 2008
    Seattle, WA
    It's a 2000 Century with a C15. I just had a new exhaust manifold and turbo put in, about 4 weeks ago along with a new flex pipe after the s pipe, and a new Walker Noisebreaker muffler. I don't have exhaust sleeves so that's out. I will take a closer look at the manifold. Hopefully it will fail gracefully.
  7. Pfuse
    Pfuse Light Load Member
    119
    52
    Aug 18, 2006
    La Crosse, WI
    Very interested in the outcome. Yesterday my bxs started making the same noise at 35+ psi.
  8. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Check the air to air exchanger for cracks with a pressure tester.
  9. Trudger
    Trudger Light Load Member
    122
    42
    Jun 26, 2011
    Beaverton, Oregon
    If you start blowing a LOT of BLACK smoke, shut that truck down or you'll overheat that Turbo, believe me, I've done it.
  10. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    I doubt it's the turbo, I'd say you have an air leak. Inspect the hoses between the turbo aftercooler and engine. You may also have a small crack in the aftercooler. As boost rises it gets worse, because the air pressure is rising and the volume of air escaping through the hole is actually making a noise like a whistle or in this case kazoo
    Big Don Thanks this.
  11. Frenzy
    331
    186
    Mar 24, 2008
    Seattle, WA
    I had to drive Sunday/Monday so I got to listen to the sounds change. It settled down to that pfft pfft pfft sound of a single cylinder leak. I think I need to get the exhaust manifold retorqed. Hopefully I will get that done on Friday, the radio will only go so loud.
