Sound Deading, and in cab rattles
Discussion in 'Freightliner Forum' started by Roanokemassey, Sep 22, 2022.
  1. Roanokemassey
    Roanokemassey Bobtail Member
    14
    5
    Jan 29, 2022
    I have 2, 2015 Day cab Coronados with 12.7 Detroit's and 13 spds.
    Air ride front axle, rear suspension and cab.
    Both are 600,000 mile trucks.
    Rattles, vibrations, and noise seems to be getting worse by the month.
    No engine, drive train or tire problems.
    1. I am thinking of replacing the rubber floor covering. It's got cracks and the insulation looks crushed.
    2. I am thinking of removing the ceiling and behind the seats interior and installing the stick on sound deading material and reinstalling the interior.
    3. Removing the door interior panels and adding sound deading material too.
    4. Both battery box lids rattle bad. Has anyone changed the way these latch down?
    5. Thinking about taking the entire plastic snap together dash apart and adding sound Deading material to all of the pieces and frames to stop noise.
    Has anyone tried to reduce the noise on these trucktruck? The old 1990s FLDs with 2 million miles are quieter to drive than these Coronados.
    Just asking if anyone has and any suggestions.
    The materials won't cost that much. And my labor is cheep on the weekends.
    If I can make it better for my drivers I want to do it.
    I have replaced the driver seats and getting the leather steering wheels reconditioned
    The trucks are in very good shape for their age, but are getting noisy to drive.
    I would appreciate all suggestion. Except, "what did you expect? You purchased a Freight Shaker" ......dont need that. I know what I have, I just want to spend $ and my time to make them more comfortable.
  3. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Rolled asphalt roofing is the cheapest and easiest sound deadening I know of. Just peel and stick on the backs of all the panels, walls, floors and doors you can reach. It adds weight though so keep that in mind.
  4. Darklance
    Darklance Bobtail Member
    22
    17
    May 25, 2019
    Salt Lake City
    I can't see how it can't but help. Wouldn't do the ceiling, don't see how that would much.
    Maybe spray the underside of the cab with the spray-on stuff. I imagine a lot of the noise comes from the interior components, like my friend's Columbia, tracking those rattles down would do a lot.
    This is concern as far as pulling the interior apart, you could make the noise worse.
  5. AModelCat
    161,251
    Fix the loose parts causing rattles rather than mask the noise?
  6. bzinger
    bzinger Road Train Member
    16,635
    66,092
    Dec 10, 2014
    omaha , ne
    Are those Coronados built on the Columbia cab or the cascadia cab ?
    I've got a million 50 on my 2013 cascadia and it's Nats ### tight .
  7. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    I don't know anything about Coronado's, but in most trucks I have developed rattles in changing the cab mounts has always made a huge improvement. Motor mounts also if the rattles are at certain rpms. Make sure to use soft rubber, I always try to get oem and once the dealer sold me some plastic telling me it would last longer. That ended up being money in the trash can.
    bzinger Thanks this.
