Someone define 'glider'
Discussion in 'Trucks [ Eighteen Wheelers ]' started by windsmith, Jan 17, 2013.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I've searched everywhere for a definition of 'glider' as it applies to trucks, but have come up short. It appears to be one of those trucker terms passed down for generations and kept in the family. I get the basic idea, but having someone spell it out would be much appreciated.
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Truck that is sold with 2 of the following not installed at factory. Engine, transmission or rears.
  4. baggedextreme
    baggedextreme Bobtail Member
    30
    4
    Jan 9, 2013
    Hope mills nc
    what i was told was a glider was for someone that had a title to a truck that has been wrecked or no longer road worthy and they just dropped there own engine in the truck but i have seen 2013 gliders on ebay and they have the engine and everything in them
  5. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Ah, missing powertrain components, therefore it 'glides' out of the factory unpowered.
  6. 25(2)+2
    18,749
    45,387
    Sep 18, 2006
    the road less travelled
    First time I heard of it was in the early 90s, when our milk hauler had a driver wreck a brand new truck; he purchased the wreck from the insurance company and bought a glider kit, the one he bought was a chassis frame with no ,transmission or drives, I believe it had the front axle and wheels and tires.
    Gliders by definition have major drive line components installed either from a donor vehicle or remanufactured installed in a new chassis, as a way to reuse resources instead of assembling all new components.
    There is no federal excise tax assessed on assembled gliders and the engine is usually an older design than any currently available on new trucks.
    I'm guessing someone could do the same thing the milk hauler did, if it penciled out.
    windsmith Thanks this.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It means a new truck without a driveline, but otherwise complete. Some can be ordered with or without drive axles. There original intent was if you had an accident and the cost of repairs exceeded the cost of the truck, but your engine and trans are still good, you could order a new truck without the driveline. It was generally about 20% cheaper than buying a new truck. We had a 1999 Sterling that wrecked in 2003. We ordered a glider and built a 2003 and used the 99 engine trans and rear.
    Nowadays, they are often built to dodge emissions. You can buy a 2014 glider and put an pre-emissions engine in and trans in and legally the emissions only need to meet the requirements of the engine year. This loophole will probably eventually close as the government tightens it's grip on emissions.
    UturnGirl and windsmith Thank this.
  8. baggedextreme
    30
    4
    Jan 9, 2013
    Hope mills nc
    18,749
    45,387
    Sep 18, 2006
    Blackfly and baggedextreme Thank this.
  10. baggedextreme
    30
    4
    Jan 9, 2013
    Hope mills nc
    yeah i seen that when i was looking at some other trucks and had to ask my dad what a glider was
  11. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Think of it similar to a kit car. You can get a kit car, either assembled, or you do it yourself. You can take that old Chevy small block and throw it in if you want. This is basically the idea behind a glider... it is a kit truck. It is ordered thru the parts arm of the OEM and not thru normal new truck process. The factory does all the major assembly, you just drop in your own engine and components. The title/registration process is the same as for a kit car. All that is required is that it meet FHWSA, FMCSA, and DOT standards.
    My 2013 FL Columbia glider, complete and ready to work, was $112K and no FET.
    I am not so sure that the loophole on the emissions will be the primary motivation for government to close the loophole on doing this. They want money. They are missing out of a basket full of cash on every glider build. They will eliminate the tax incentive before they get to emissions. They will let them be built, at least for a while, and will change the tax law to eliminate the avoidance of FET. So far, it hasn't made it on the radar enough to really get their attention. Stay tuned.
