Solo clutch over-adjusted
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 4x4_Welder, Oct 10, 2014.
  1. 4x4_Welder
    4x4_Welder Medium Load Member
    300
    213
    Sep 16, 2014
    Eastern Orygun
    One of the drivers here didn't understand what a clutch brake was and blew two of them out. The first one I thought I may have installed wrong, but the second only lasted a day and I k ow it was in right. The real problem now is that it has a Solo clutch, and it has now self-adjusted to have about 3" of free travel.
    Is there a way to back off the adjustment so I can put a new clutch brake in? The driver has been educated now.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    most drivers need to be educated.
    there's really no need to be mashing the clutch pedal into the engine compartment.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    To release the adjustment you hold the pedal down and move the slider leaver on the preasure plate back, to adjust if needed you quickly pump the pedal up and down three times.
    Just a thought!
    magoo68 Thanks this.
  5. 4x4_Welder
    300
    213
    Sep 16, 2014
    Eastern Orygun
    Ok, I didn't know if the adjustment would work in reverse like that.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    The basic procedure is to hold the clutch down, move the tab to "new" and release the clutch. Then install the caging bolts, push the clutch 5 times, then remove the bolts.
    It is easy to break the tab off, so be careful, don't force it if it wont wont move. Follow the directions carefully in the manual that Heavyd posted. If you break the tab off, you're screwed.
    Proper linkage/clutch brake adjustment on a solo is even more critical than manually adjusted clutches, make sure it's all set up right.
    JohnP3 Thanks this.
