...So what's this infamous actuator valve on C15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lucar, Aug 26, 2013.
  1. Lucar
    Lucar Road Train Member
    1,396
    889
    Aug 22, 2012
    Texas
    I keep reading everywhere about the troublesome "boat anchor" 2007 and up C15 acert.. (which is what my "new to me" truck has) The more frequently mentioned is
    The valve actuator. Can any experienced drivers and techs such as Mr. Haney educate me on this please.
    How many are they?
    What do they do?
    How to prevent any troubles with these?
    What kind of cost will I look at in case sthiz break?
    Thank you.
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I'm no mechanic. But I do have almost 2 yrs with a C15 ACERT motor and I can honestly say that I personally would never buy a truck with this motor.
    Its great when everything is working right. But there are so many problems. The Valve Actuator is only one that you may or may not see.
    The way I understand it the ( Someone correct me if I am wrong ) ACERT motors have VVT (Variable Valve Cam Timing). Under normal driving conditions the motor works in an efficiency mode with 1500 ft/lb trq. Then when needed the cam timing changes and the trq is increased to 1850 trq. Thats why the valves sound noisier at times and quiet(er) other times. The valves need to be serviced every 250k mi also.
    In my opinion and as mechanics have stressed to me... "There is just way too much going on in that head".
    Other problems I have encountered are Jake brake problems. Consistent regen issues stemming from anything from the ARD head, upper or lower temp sensors not seeing eye to eye. DPF filter issues. You name it.
    I love the hill pulling torq. The low rpm pulling power. Good motor when everything is working right. But thats not very often in my experience.
  4. wstar2003
    wstar2003 Light Load Member
    157
    195
    Jul 14, 2013
    I believe 3 per head
    They are part of CAT version of EGR. They open the intake on the exhaust stroke to let exhaust back into the engine.
    The main big problem with the actuators is they break studs. Then they bang on the top of the head and scar it. In worst cases they can ruin the head. But you will be able to hear it first usually. It will run rough and miss. About the only thing preventive you can do is check with CAT and see if the updated studs have been installed. I haven't had any trouble with the updated studs, yet. They will also break rocker arms and turbo studs just so you know.
    If you hear something funny in the engine it will usually be an actuator, rocker, or a turbo stud
    The most expensive actuator failure I have had was $2200 but that was including a stud update so it wouldn't happen again.
    That being said mine have been OK motors. One pushing 900k and the other two about 800.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    the valve actutators are on every cylinder incorporated in the jake housings.
  6. wore out
    wore out Numbered Classic
    15,347
    185,346
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The last two post hit the nail on the head, definetly check to see that you have the updated studs we have seen almost no trouble with the intake valve actuators after installing the update kit
  7. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    I just got done installing the new updated studs, broke the ones in the middle rocker box and while I had it down I replaced all the studs, there are six studs and one bolt per rocker box. I also replaced both wiring harnesses,
    the actuator codes are a lot of times a low voltage code, oil gets into the connector and throws a code, there is a updated connector that has a boot type seal that prevents this . at 833,000 mine nows runs like a new one smooth as silk. the odd thing is the updated stud is thinner than the old outdated stud right up under the six point area in about the middle of the stud
    mine did exactly as stated, seems ed to lose a little power, then ran a little rough , and found cylinder 3 and 4 had broken all the studs, didn't hurt the head or anything else, they will sometimes drop a valve in this scenario.
    Warren Earp Thanks this.
  8. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Just to clarify some of the above posts. There are 3 actual IVA/jake housings in the head (2 cylinders share a housing) and on each housing are 2 oil solenoids (these are the normal wear items which along with wiring issues cause fault codes). The IVA housings DO NOT open the intake valves letting exhaust back into the intake. The IVA does not have enough power to overcome the initial seat pressure of the valve springs. It does however have enough staying power to hold the valve open during the start of the compression stroke letting some of the intake charge to flow back into the intake and "pre heat" it for better combustion. The whole ACERT engine is based off a modified Miller cycle combustion process (a different but similar 4 cycle engine process). Many of the associated problems with the IVA come from brittle wires, bad connections, dirty oil, and improper oil weight. Since the IVA uses engine oil it is vital to keep the oil even cleaner and the right viscosity so it flows through the small passage ways correctly.
  9. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    the only issues I've had with my NXS C15 is I've had to replace the IVA oil pressure solenoid a couple of times. But then there is the problem with the right side of the engine being cluttered with the two turbos and other emmission related components that makes working on this side of the engine difficult. But if you never have any problems with the waterpump, oil cooler, exhaust manifold, or that silicon coolant hose behind the oil cooler you'll be fine.
  10. Lucar
    1,396
    889
    Aug 22, 2012
    Texas
    Thank you all for your responses. Now with the truck and going on my 6th month, I've replaced the IVAs (all 6) and the truck keeps giving me the check engine light. Today it is IVA 5..The wire harness had been fixed by dealer, and it lasted me (check engine light out) roughly a week, now it's back on. Regularly the turbo boost is 30 psi, during that good week it was going up to 40; would this be weather related? (colder-denser air)How difficult is it to change the IVAs myself? Should I jump in and replace harness(es) and oil solenoids?My truck is set at 475, and sometimes the engine is noiser but it does not happen often (3 times a week), why would this be?Ive done a lot of work on this truck and im set back for almost 10 grand of work, Iincluding a tow. I'm seriously debating the "after treatment delete or replacing the truck for another engine manufacturer. The ARD head is new, 6 IVAs, filter has been cooked, transmission work done, sensors, sensors, sensors, computer updated, and other #### I can't even bring up at this time. Am I too far in to give up? Or should I jump out of the sinking ship?
  11. wore out
    15,347
    185,346
    Jun 5, 2013
    Not sure if your saying they repaired the harness under the valve cover or the external harness. The internal harness is almost impossible to repair due to the heat and oil in my opinion its best to replace it if you have any trouble. On the outside it depends on where its damaged to the best way to repair it. If the resistance is altered much at all from the repair it can alter the data to or from the ECM. Weather pak terminals like the factory uses or sodier and heat shrink is best for external repairs.
