I'm trying to get a good grasp on shifting because I start CDL school shortly and this is what I've gathered. Please let me know if I'm on base or not. I have been watching youtube videos and looking up how to's on the internet. It seems as though when you are starting out you push in the clutch and put it in 1st, then slowly let out the clutch and give the truck some gas. Now some sources say the truck should start rolling slowly on its own when you've completely let off the clutch and some also say to fully let off the clutch before giving it gas.
Now I'm sure my instructor will guide me to the correct rpm's in which to shift gears. This is what I've gathered on shifting the gears after starting. In double clutching when you first push in the clutch you put the shifter into neutral and the second time you push in the clutch is when you put it into the next gear. (How am I doing so far?!?!?)
Now I got the low/high selector pretty much figured out so I'll fast forward to downshifting.
For downshifting I've gathered that when your in a gear say 5th for example and you want to go into 4th you should be in the correct rpm range and speed and as you push in the clutch the first time you put it in neutral and while its in neutral you increase the rpm's by a couple hundred and then double clutch the second time to get it into 4th. (I think I'm right but not sure).
Now here's a question: Do you apply the brakes at any time while downshifting or do you just stay off the accelerator (with the exception of giving it rpm's while in neutral) and let the truck slow itself down and just downshift as its coming down almost naturally?!?!?
I know that practicing is the best way to figure it all out, but I want to have a good sense before I go in. Sort of a game plan if you will.
So this is what I've gathered to correctly upshift & downshift a semi.
Discussion in 'Questions From New Drivers' started by gearjammer1978, Apr 30, 2013.
nitpicky lecture over...
As to your questions, when starting out I rarely press the accelerator until the clutch pedal is completely released. When I do 'slip the clutch' it is when I'm starting out in a higher gear in order to clear a busy intersection quickly. In doing so, I am knowingly trading the life of the clutch disk for a little better acceleration off the line. For you, in school, this shouldn't come up...
gearjammer1978 Thanks this. -
Thanks Double Yellow, this break down helps me as a rookie driver. Double clutching is the hardest thing for me so far. I drove a manual for 15 years and old habits are hard to break. I just had trouble not pushing the clutch all the way when I shift. The hardest thing for me is to just barely push the clutch to shift. When I did shift correctly it shifts so smoothly that if feels like I missed the gear.
My advice for Gear Jammer is to actually try to not think and worry about about it so much and try to relax and just do what your trainer says. It is easier said than done, but its the best piece of advice I can give you.
Just remember slow and smooth. Seems to be the key to driving a truck.gearjammer1978 and Rugerfan Thank this. -
You should never "slip the clutch" in a heavy truck unless it is absolutely necessary (an example would be starting a heavy load on a steep grade when the truck is geared too fast, although, you should avoid these situations generally).
Heavy truck clutches are not made to slip, they are made to grab, and it does wear the clutch badly when you slip it. You should be selecting a low enough gear to start the truck without having to touch the throttle until the clutch is fully released.
Regarding up shifting, it's a relatively simple procedure to explain, but, takes practice to get good at. It's not entirely accurate to break it down into "steps", as, it should become a fluid motion. When you begin it will be a series of steps, but, as you get practiced at it, it will become a more fluid motion rather than a progression of a.), b.), c.), etc. When you engage the clutch, pulling it out of gear shouldn't be a matter of even a second, it should almost be (though not quite) concurrent with you engaging the clutch. Your time spent in neutral is all about timing. Unlike a car or a pickup, a heavy truck transmission is not synchronized, meaning you CANNOT simply floor the clutch to get it into the next gear. You, not the vehicle, has to time things. Transmissions and engines react differently, so every truck shifts a little differently.
Regarding down-shifting, it's the same process, in reverse, except when you go into neutral you'll "blip" the throttle. How hard you are going to have to stab the throttle is also going to vary from truck to truck. Some trucks have a very stiff throttle spring, other's, almost none. The stiffer the throttle, the harder you'll be "tapping" the throttle to bring the RPMs up.
The only time I touch my brakes when I'm downshifting is if the light goes red or something happens in front of me where getting stopped is more important that getting the truck into gear.
The range change is actually a matter of debate, for some. A lot of guys are taught to "pre-select" when using the range change. This means you flip the switch up or down (depending on whether you're upshifting or down-shifting, respectively), and then go into neutral. The transmission will not shift the range until it passes through neutral, so, until you pull the truck out of gear, if you are in 5th on the low-side, it will not up-shift the range until you up-shift the transmission. HOWEVER, I do not really "pre-select" when I'm shifting the range-change. I flip the range basically right as I shift. Its simply the way I was taught.
Another thing to understand about the clutch in a heavy truck versus is a car is that you DO NOT engage that clutch fully when you are shifting. You only engage the clutch far enough for the transmission to go in and out of gear. Because heavy truck transmissions are not synchronized they feature what is called a "clutch brake". It's a device that slows the transmission down when the clutch is fully engaged. You will use this to put the transmission into gear when getting started. A transmission is still turning when in neutral, and to get it in gear you must slow the rotation of the gears. Engaging the clutch brake achieves this purpose. HOWEVER, engaging the clutch brake (flooring the clutch pedal) at speed is a good way to destroy the clutch brake. So, DO NOT fully engage the clutch when you are shifting, you'll tear up the clutch brake. Only enough to go in and out of gear.
As a matter of simplicity, leave the jake off when shifting until you get good enough at it to handle it with the jake engaged, if ever. Some drivers never turn the jake on when shifting.
Shifting, more than anything, is a matter of practice. Your first month of driving a truck will be a circus of bad shifts. You'll pick up up-shifting faster than down-shifting, up-shifting is simpler, the coordination between foot, arm, and brain is less complex than on a down-shift.
Practice, practice, practice.gearjammer1978 Thanks this. -
ColoradoGreen,
Great advice!!! I'm trying not to make a mountain out of a mole hill. I know it'll take practice but I'm trying to keep it as simple as possible. Getting all worked up will only make things worse. -
Both responses were great imo. I've been driving now for about 9 months, so for what its worth just relax. The shifting will come and by time you are out of training you will have it down. Somebody might say that I am minimizing it, but you really can and probably will overthink a lot of things. Shifting being one of those things. The comment abot fluidity vs a to b to c is right on. I float, keep the Jake's engaged all the time and really never touch the brake unil the final few feet before stopping. The Jake's jacked me up during training at first and my finisher would reach over and turn them off....lol. But as you become more fluid and youf timing becomes second nature you will just go up and down the tree without a thought or glance at the Speedo.
Oh and like the other responses, DO NOT slip the clutch. These trucks have more than enough power to pull out without stalling as you ease off the clutch provided you are in a low enough gear vs weight. In 9 months I've only had to feather the throttle once and that was starting from a stop on a steep upgrade weighing in at 79300. (Like Colorado referenced)
All great advice. Just relax and listen to your trainer. Know that you WILL grind gears and miss shifts, after more than 600,000 miles I stilll do on occasion. Biggest bit of advice...ask lots of questions about everything. You are paying good money. Get what you are paying for!
If you (or your instructor) ever feel like you are getting too rough with your shifting, try holding the shift knob with just the tips of your thumb, index, and middle fingers -- it can help you feel what's going on inside the transmission a lot better than when you're doing white knuckled bench-press motions.
Colt seavers Thanks this.
