So here's a thought, what is "an accident"?
Discussion in 'Trucking Industry Regulations' started by outerspacehillbilly, Mar 4, 2010.
  1. outerspacehillbilly
    outerspacehillbilly "Instigator of the Legend"
    4,349
    2,430
    May 28, 2009
    The Who's Your State
    Well I was setting here reading a thread from a driver saying he got screwed by a company because he had struck a fixed object while backing in and they put on his DAC that he had an accident.
    Well we all know that on any application they ask about your driving record, accidents, etc....... So my question is what do they want? Do they want to know about you backing into a small pole that cause $200 worth of damage? Some companies I have worked for called things like that an incident some call them accidents.
    Or do they want to know only about accidents that required a police report, DOT report etc.... that are recordable accidents? Just made me think a little. Anybody know the procedure on that sort of thing?
  3. blackw900
    blackw900 The Grandfather of Flatbed
    5,817
    7,678
    Jul 12, 2009
    A.W.O.L
    To me it's simple...Accident = Any object that isn't supposed to come in contact with the truck coming in contact with the truck causing any kind of damage.
    If the object is stationary, It's the drivers fault every time!
    outerspacehillbilly, Big Don and Kabar Thank this.
  4. Saddle Tramp
    Saddle Tramp Medium Load Member
    590
    235
    Jul 13, 2009
    laurel, nebraska
    :biggrin_25514:Blackw900 is right, you hit anything with your vehicle you are at fault, no matter how minor.:biggrin_25526:
  5. truckerx1
    truckerx1 Light Load Member
    177
    148
    Nov 16, 2009
    Any time your truck comes in contact with any other object it is an accident. Pulling on a soft shoulder and getting stuck etc. is an incident. The main thing to watch for is preventable and non-preventable. Many drivers confuse chargeable and preventable. You can have a preventable accident that is not chargeable. I'll give you an example: You are parked in a truck stop but not in a marked space, and your truck is hit by another truck weather the other truck is backing or whatever, you just had a preventable because you shouldn't have been parked there. If you are in a marked space and your truck is backed into it is a non-preventable. Another example is say a deer jumps out and you hit it. That is a non-preventable. If you swerve and roll your truck or hit a guardrail or nail your brakes and jack-knife that is preventable and most likely chargeable.
  6. outerspacehillbilly
    4,349
    2,430
    May 28, 2009
    I agree with both of you, however, the question was do you put those on an application where it asks about accidents or only something bigger that has a report filed with it?
  7. outerspacehillbilly
    4,349
    2,430
    May 28, 2009
    This was my question about job applications.
  8. truckerx1
    177
    148
    Nov 16, 2009
    On and application it is always best to be honest. If you fail to be up front your application will most likely be disqualified or if you get to the point of getting the job and it is found out latter that you lied by omission you will most likely be fired. If you had an accident no matter how small it will be on your record from your previous employer.
  9. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    In other words, if your truck comes in contact with ANYTHING, it is an accident. Unless, of course you intended to hit it. (But that is a different ball game altogether.)
    If there is ANY damage incurred by anything or anybody, then you should not leave it off an application. Better to get it all out in the open, right away. If they don't give you a chance to explain what happened, then you are better off not working for them.
    If you have had a lot of "little" accidents, they really may not look at you. I know the safety department at Knight used to say something to the effect that any driver involved in three or more "little" accidents was very likely to be involved in a MAJOR accident.
    outerspacehillbilly Thanks this.
  10. whatwasithinkin'
    whatwasithinkin' Bobtail Member
    7
    Mar 3, 2010
    My thoughts are about the time frame of it all. If the company uses the new "prescreening" database then it's 5 years. At what point is a driver finally forgiven by the industry if there was a preventable or chargable accident and will they be hired again at some point?
  11. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    I was written up for having a "backing accident--struck another vehicle" because I was backing into a dock and my trailer struck my APU. the APU is considered another vehicle at Werner. Still have a job though. ;)
    This is my last trucking job so i dont care about my DAC. But i'll still be pissy if they put that on my DAC when i leave.
    A while back a team of safety guys came to the Dollar General South Boston, VA Werner Dedicated Office. These guys followed drivers around watching their driving, backing, unloading. (i have to say, you'll never get away with following ME....i'll call 911 as a suspected hijacking attempt). Someone was fired for doing 3 over the speed limit (a freightliners speedometer isnt even accurate enough to tell if youre doing that), someone was fired for touching grass backing into a dollar general. OMG. SOMEONE TOUCHED GRASS AT A DOLLAR GENERAL. no damage. fired as an accident.
