Im sitting on the side of the road... the weather turned today. I need to chain but dont have bungies. Can i run chains without bungies?
snow chains- off road driving... to bungie or.not to bungie
Discussion in 'Questions From New Drivers' started by indy_colts_fan, Nov 2, 2012.
if you're chains are properly sized for your tires, and if your chains are not "worn out" and/or you have a substantial amount of tread remaining, I'd say you can probably run without bungies, IF they are properly installed and have no "issues" as some chains do. If you've never run chains before, I don't recommend you attempt this, especially in the dark.
sure, make sure they are tight, if u have them little cam thingies for tightening them you'll be fine
I never run bungies just make sure there snug. Never had a set come off.
I have the cam-lock style chains. I never use bungees.
I'll take his word for it... -
They are also for my tarps, otherwise, my tarps would end up spread across your windshield!
As for flying tarps...its flying anything I've watched for and been able to dodge. Guess they call that defensive drivin' or something like that. -
I think all there is cam locks. If you got non cam locks there probably older than dirt and rusted out. They'll start breaking links then your SOL. Word of advice don't hang chains only to dry then put them in your storage box. They'll rust the hell out if you keep them hanged all the time. Then next season your not on the side of the mountain with broken links spinning out. My company I always grab new set chains to start the season but I know not everyone can do that but if you can grab a new set.
