Smoke tarp
Discussion in 'Flatbed Trucking Forum' started by MJ1657, Jan 24, 2014.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I want to get smoke tarp for occasional water pipe loads. Do you guys like fitted or just a plain flat tarp with a couple rows of D-rings.
    I'm leaning towards a fitted tarp. Tarpstop has them that are 8x8x2.
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    fitted nose tarps are great when they fit right. Such as insulation or lumber that is exactly square and 8' wide. anything that is a little narrower or not shaped square you'd be just as well off or better with a 10 x 12, even a 16x16 or a scrap from a ruined tarp can work just fine.
    MJ1657 Thanks this.
  4. Ruthless
    Ruthless Road Train Member
    8,786
    85,967
    Aug 28, 2010
    The City.
    I bought a fitted, specifically I wanted one for that green pipe...figured fitted would keep it on while I'm trying not to fall off of the ladder... Results pending on that. If you throw a strap/chain over top to keep weight/ frictional tension on the top side a flat tarp will work just as well
    MJ1657 Thanks this.
  5. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Fitted is best. A Ratchet strap so it don't flap. Tech Tip. Bears leave you alone if your tarp looks good.
    MJ1657 and JPenn Thank this.
  6. 6wheeler
    6wheeler Road Train Member
    2,696
    4,772
    Aug 30, 2009
    Blue tarp from KMart. 10' bungee and roll.
  7. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    those get shreadded on one trip
  8. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    I always put mine on before they load it on the truck put a 2" on there and your good
    Cetane+ and MJ1657 Thank this.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    i just use a padding tart that doesnt have holes or a steel tarp, but I aggree with Bayou....tarp it on the ground before it gets lifted.
  10. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Is it fitted?
  11. BAYOU
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    no just a 10x10
    MJ1657 Thanks this.
