Smoke during regen
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by krupa530, Feb 14, 2023.
  1. krupa530
    krupa530 Light Load Member
    295
    1,134
    Dec 3, 2014
    Orem, UT
    So I’ve got an intermittent problem. W900 X15 565/2050. Started to blow a little whitish grayish smoke when it’s regenerating. Only when you’re hard on it. Let off and it’ll stop, or drop a gear and it’ll stop smoking. Only does it when it when regenerating. Got 677,000 miles on it. Rebuilt at 555,559. Never done this before. Probably notice it once or twice a week. Smokes at the most 15 minutes total then it’ll be fine.
    Any ideas. @Goodysnap..
    D.Tibbitt Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    If it is smoke for sure and has color and not just steam I would suspect the DPF may be leaking either cracked or around the body. If it has been cleaned in the past I would plan on new or reman in the future. Step one, wipe the inside of the stack with your finger and see if it’s dirty.
    D.Tibbitt and krupa530 Thank this.
  4. krupa530
    295
    1,134
    Dec 3, 2014
    Orem, UT
    Sounds good. Thanks. It was cleaned once at Cummins with 500000 on it.
    Definitely smoke and not steam. I’ll check the stacks tomorrow to see if they are dirty.
    D.Tibbitt and Goodysnap Thank this.
  5. AgPilot1
    AgPilot1 Light Load Member
    201
    1,047
    May 29, 2022
    Are you sure it’s not the regen injector doing it’s job? Cummins inject fuel into the exhaust after the turbo during regen. That’s how they get everything hot enough for the regen. I just had mine at Sioux Falls Cummins because at idle it would blow white smoke intermittently. Temps were around 0° and it was injecting fuel trying to keep the after treatment warm.
  6. krupa530
    295
    1,134
    Dec 3, 2014
    Orem, UT
    It’s always been around 45 to 50 degrees ambient when it’s done it. Just never done it before for 650000 miles.
  7. AgPilot1
    201
    1,047
    May 29, 2022
    They said they will also smoke during regen when something thing (I forgot what they called it) get old and hold the fuel so it doesn’t get a clean burn.
  8. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    White/greyish smoke is usually a sign of a degraded DOC. Clean or replace the injector and recheck for temp increase during a forced regen. If temps are really lazy to build between 500-700 and this is when it produces the smoke, it is DOC time.
    krupa530 and D.Tibbitt Thank this.
  9. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    469
    1,396
    Feb 8, 2022
    Raleigh NC
    I’ve had this happen a few times. Only done it whenever my APU would go down and I idled my truck a couple nights.
    krupa530 Thanks this.
