Smoke coming out of where you put engine oil
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Apr 7, 2020.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    I drive a Cummins isx and there is a lot of blow (smoke) coming out of where you put the engine oil in. Can somebody please offer some advice on what’s happening
  3. 86scotty
    86scotty Road Train Member
    4,376
    11,616
    Aug 27, 2017
    Appalachia
    Nut behind the wheel.
    scottied67 Thanks this.
  4. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Did you leave the cap off???
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Crankcase filter dirty or worn engine parts is my guess for the blow by ..
    BUMBACLADWAR, Brettj3876 and Gurjap Thank this.
  6. Gurjap
    57
    11
    Mar 18, 2020
    I only took it off the cap while I was checking it
  7. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    While it is running?
    What are you checking?
  8. Gurjap
    57
    11
    Mar 18, 2020
    yes it was running.
    my crankcase filter gets dirty very fast so I checked where I was putting the oil for blow by and there was much more than I expected.
  9. Dave1837
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Oil and smoke will come out of the filler while it's running, that's normal on every engine. It shouldn't be off while it's running but just for a few minutes won't matter. I left mine off on accident and after my trip I found 2 gallons of oil sprayed all over the inside of my hood. I'd get your blow-by tube/filter cleared as soon as you can
    Gurjap, Brettj3876 and rachi Thank this.
  10. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Thats just how isx act when crankcase filter is plugged up and when pull fill cap blow/by blows out fill cap, try to change oil filter one time in the middle of oil changes to make it last longer till next infrane?
  11. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    Look under the truck, you will likely see blow by there too.
