Smoke coming from under the cab driver side during regen.
Discussion in 'Ask An Owner Operator' started by kay_ray, Nov 25, 2020.
  1. kay_ray
    kay_ray Medium Load Member
    485
    1,206
    Jun 6, 2019
    does anyone have any idea what this might be .it only happens when truck regens. Thanks
  3. Judge
    84,414
    So smoking during a regenmeans the DOC is not working efficiently. The DOC could be plugged, dirty, or simply worn out and needs replacement. A faulty injector could also be to blame due to improper spray pattern or volume. First step is to remove and clean, (or just replace) the doser injector.
  4. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Was the wind blowing and blowing exhaust smoke back under truck?. assuming you have a weed burner exhaust. If wind not blowing you may have a clamp on exhaust leaking or a hole. But looks like lots of moisture on the undercarriage sure it wasn’t just water vapor
    77fib77, flood and kay_ray Thank this.
  5. kay_ray
    485
    1,206
    Jun 6, 2019
    I ll prob replace the doser injector and see if it helps . Thanks
    77fib77 Thanks this.
  6. kay_ray
    485
    1,206
    Jun 6, 2019
    No wind but it might be an exaust leak too. I dont think it was moisture. That smoke smelled like burnt def/diesel
    Siinman and jason6541 Thank this.
  7. jason6541
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Yep, sounds like a doser issue
    flood Thanks this.
  8. Simms
    Simms Bobtail Member
    28
    34
    May 22, 2014
    Knoxville, TN
    My volvo did this at 500k
    It was a blocked/clogged DEF filter
    the exhaust backfilled to the turbo where the turbo and flextube met
    Siinman Thanks this.
  9. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    Are you sure it was the DEF filter, or did you mean a DPF or DOC? The DEF filter is located on the pump and doesn't affect the exhaust flow, it only filters the fluid.
    kay_ray and AModelCat Thank this.
  10. Simms
    28
    34
    May 22, 2014
    Knoxville, TN
    Yes, my bad. The DPF (big filter in the burner unit)
    It can clog and make the smoke backfill to the turbo if it clogs up enough.
    Thats what happened to mine.
    kay_ray and loudtom Thank this.
  11. AModelCat
    154,264
    Exhaust leak. Even if the DPF is severely restricted the only way exhaust is getting out of the pipe is if there's a leak. If the DPF is plugged that badly that it'll push that much exhaust out of the tiniest of leaks, you're likely going to feel a huge loss of power.
    InTooDeep, kay_ray and loudtom Thank this.
