Small radiator infront of main radiator???
Discussion in 'International Forum' started by WMGUY, Jun 4, 2021.
  1. WMGUY
    WMGUY Road Train Member
    1,683
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    2012 prostar with maxxforce 13. I have a coolant leak that someone tried to patch at one point.
    It is coming from a small what looks like 2 peice radiator that mounts in front of the main radiator and behind the inter cooler. It looks like there is an upper and lower unit.
    Does anyone have the actual name or part number for this?
    Thanks
  3. AModelCat
    154,230
    Probably not a coolant leak. My guess is dye from the A/C system.
  4. WMGUY
    1,683
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    No its coolant. A/c condenser mounts to the front side of the intercooler. A good distance from this
  5. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    If max force that is a small radiator for the egr cooler. Follow lines up and it will lead to egr cooler at top of engine.
    is it mounted down low in front of cooling package down low?. been some years but I do believe that is cooler for egr.
    WMGUY Thanks this.
  6. WMGUY
    1,683
    800
    Jan 1, 2011
    Nine Mile Falls, WA
    Thanks that makes sense. It looks like a 2 peice unit. The top line comes out of the egr cooler the lower line goes to the small heat exchanger for the low pressure turbo. The section is low behind the bumper. I'll see if I can find it with that info
  7. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Yes, aux radiator for the egr cooler.
    WMGUY Thanks this.
