Has anyone ever used a product Bar liquid aluminum or similar to stop a small radiator leak? Just wondering if I can postpone this repair a bit.
2009 Cascadia DD15
Small Leak from radiator
Discussion in 'Freightliner Forum' started by David Noriega, Dec 14, 2015.
Thought when they started leaking you just crimped off the line thats leaking. Unless its a sidewall in which you be screwed.
futurenow Thanks this.
Make sure you use distilled water and stay up on DCA additives if using green coolant.
never use stop leaks. top of liners get plugged.futurenow Thanks this.
