Slow cooker on the road
Discussion in 'Driver Health' started by Mmitchell0171, Apr 19, 2019.
  1. Mmitchell0171
    Mmitchell0171 Bobtail Member
    12
    Jul 23, 2018
    so my company won’t allow a power inverter in the truck so I can only use the 12 volt inverters that only push up to 180 watts. Does anyone know a good slow cooker that uses less than that? I would prefer not to use the road pro as I had one catch fire.
    I found a 3 quart that claims 200w output and was also wondering if anyone know if that is its power output on high setting, or overall. If it uses less than that on low I can just cook on low all the time.
  3. The Gels
    The Gels Light Load Member
    212
    286
    Apr 13, 2019
    Shreveport, Louisiana
  4. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,209
    Oct 25, 2015
    Fort Worth
    I use a lunchbox cooker just fine. Canned stuff
    homeskillet and flood Thank this.
  5. homeskillet
    homeskillet Road Train Member
    5,642
    40,781
    Jun 1, 2013
    Dayton, OH
    Sorry for your mishap, OP.
    My RoadPro slow cooker works great.
    Good luck with your search.
  6. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,521
    May 28, 2015
    I used to used a little crock pot slow cooker and a 300/400w inverter.
    It was a little two quart model and it taxed the inverter.
    It really depends on the quality of the inverter, AND where you get your power supply.
    If you can tap the batts, it'll likely work fine.
    Mine was a cig plug and I can tell you for a fact that it did cause the plug to burn out.
    I was watching tv on a break and heating some grub when I smelled wire burning.
    That was the end of that.
    I did it for a long time before the issue.. but it could have been a mess.
    Bought a 2k watt and wired it to the batts. Use a microwave now.
  7. PE_T
    PE_T Road Train Member
    The problem is that inverters without an APU can damage the truck batteries. You can still use an inverter, but make sure your engine is on and idling at 900 RPM or more. Some people have their slow cookers running while they’re driving. Just keep the slow cooker next to you in case you need to turn it off.
    Personally, I would install one and not tell the owner. Just make sure you don’t use it while your engine is off, and remove the inverter before you turn in the truck (at least for OTR drivers).
