slip seating
Discussion in 'Questions From New Drivers' started by latebloomer, Jul 2, 2012.
From my understanding of the concept, and I could be wrong, slip seating means that when you go home for your hometime, you drop the truck in the yard. Then when you come back to go back on the road, you get a different truck because someone else has already taken your truck.
Instead of having a truck exclusively assigned to you, several different drivers will operate it. Running OTR, it probably won't be an issue so much as it would be for LTL and local drivers with larger companies.
latebloomer Thanks this. -
that's what I thought it meant,was done to me constantly causing loss of pay,loads,and eventually the job
Slip seating is mainly day cabs local or out and back. Truck will run 24/7 usually.
Make sure you cut the truck off, roll the windows up and fart on the seat before leaving it, preferably after a big lunch at taco bell....it's good luck for the next driver
Just not TOO much taco bell, or it could turn into "slippery seating", and that's no fun for anyone!Rick_C and WitchingHour Thank this. -
Don't work for a company that does this. Unless you can go home every night.
Slip seating doesn't necessarily make a company bad. If it's a crappy company to work for, chances are, they'd be a crappy company to work for either with or without the slip seating. Although, if I were an OTR driver, I think I'd find the slip seating to be way too much of a hassle to put up with.
thanks, I Understand, now what's the difference in a 10sp and a SUPER 10
