Slime and other similar tire leakage stoppers
Discussion in 'Ask An Owner Operator' started by Wildcat74, Jun 29, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    Has anyone here used this type of product with any success? I work in construction and go thru scrap and recycle yards frequently and they are all heavy with screws nails etc. Today while getting loaded I found a nail in my end dump tire. And then another. And another. All told between 2 tires there was 5 nails and I'm sure there are more elsewhere that I didnt see. I hate having to inflate my tires every single day for 30 minutes before I go to work and I'm sick of blowouts due to pressure loss. Just last week I had to replace a steer that had maybe 5000 miles on it due to a nail going in right on the last tread, on the shoulder of the tire. I was told they couldn't get a patch to work there so I got to buy another brand new steer tire.
    I know tire guys hate the stuff but has anyone used tire goop with any success? I've heard if it doesn't work and you then get a flat that it pretty much makes the tire unpatchable, any truth to this? Would love to hear what you all have to say, I'd really like to get my tire costs down.
  3. Allow Me.
    10,642
    12,108
    May 28, 2009
    Rancho Mirage, Ca.
    I've used it on motorcycles, worked OK. Hole needs to be real small though.
  4. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    There is truth to it. Once you use Slime the glue will not stick to the rubber where the slime has come in contact with the rubber. Doesn't matter if you use a plug, patch, or plug patch it will not stick. I will not ever use the stuff and I advice others not to use it. You are better off with a tire repair kit to fix those rather than Slime.
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Never had any luck with even external plugs (except a plug gun) with any tire with high pressure. The slime works great in lawnmower tires and maybe even car tires but with 100psi+ it just blows out the hole.
  6. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    I went to con-expo this year and came across a similar product that had a heck of a lot thicker consistency than the slime brand that was being marketed to commercial truck owners and this was the stuff I was thinking of using. I'll have to find the brochure I got from their booth and link their site. In the brochure they had a picture of a guy in a diesel pusher motorhome with 24.5's that smashed his wheel bead up a good 2 inches and this stuff sealed the hole well enough for him to limp the thing to a tire station 50 or so miles away (according to their brochure anyhow). They had videos of the stuff in action at the booth as well and it seemed legit. I may buy some and use it on some tires but now others and just be a little scientific about it with the 2 control groups. I'll post the link to the product here when I find it.
  7. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    Just keep a good supply of tire gauges. I wouldn't use it.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    The thing with that stuff is it is packaged with a solvent to keep it's liquid form until use. It could be a hazard to a tire changer guy later on. Kaboom! Another thing is if it coats the inside of the tire unevenly, then you have an unbalanced tire.
    But if it's an emergency situation that can save you a buck, go for it. Just let the tire guy know you used it. When I ran rolloff and went to the landfill alot, it was easy to pick up nails/screws. We always kept a plug kit and fixed our own tires. It's not like you get many inspections running local.
  9. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    While looking for the particular brand I found this: http://www.goodyear.com/truck/technology/duraseal.html
    Seems as though if a tire company is willing to endorse this kind of technology it's at least safe, to reply to the concerns of CondoCruiser.
    I've found several other brands of "Commercial Grade" tire sealant, I think I'll be doing some looking into things and making a choice and trying one of the brands out. At this point it's going to be difficult to do anything that's going to make me replace MORE tires.
  10. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    Here is the brand that I got the information from at Con-Expo in Vegas this winter: http://www.amerseal.com/
    This is the particular testimonial that I had previously mentioned: http://www.amerseal.com/assets/docs/Bus_Rim_Leak.pdf
    Here's a testimonial from a trucking company with actual noumber breakdowns and an explanation of how the product has saved them money: http://www.amerseal.com/assets/docs/Southern%20Illinois%20Motor%20Xpress%20Report.pdf
    I think this is the brand that I will be going for. In the FAQ section they mention that this particular brand is completely water soluble. They also state that in independent testing this product sealed 86 individual 1/2" punctures in a 14-ply truck tire while it was still in use on the truck. It says the product is completely non-flammable and that it will not cause corrosion to any metal surfaces.
    I'll keep everyone posted here on whether this stuff works worth a darn for me.
  11. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    I just have to wonder if it will gum up your tire gauges like most of the other stuff will. (I know, it is a hell of a lot cheaper to replace tire gauges than it is tires. . .)
