Sliding axle tilt recovery trailer
Discussion in 'Canadian Truckers Forum' started by BobO1176, May 29, 2024.
  1. BobO1176
    BobO1176 Light Load Member
    139
    202
    Oct 29, 2021
    Is any particular brand better than the others? The most widely available here would be Deloupe and Doepker.
  3. roundhouse
    roundhouse Road Train Member
    3,130
    7,038
    Jul 11, 2018
    Landoll is popular in the states .
    Diesel Dave Thanks this.
  4. Albertaflatbed
    Albertaflatbed Medium Load Member
    333
    877
    Nov 20, 2022
    Nisku, AB
    I run a deloupe, have no concerns with it. Well constructed, the one I use has the in deck rollers you can raise and lower if winching on seacans or whatever which is handy.
    It's also set up with a generator and hydraulics all run off the trailer so a truck without a pto can run it. This has been more reliable than I expected
    In the past I have used landoll and ez2load, the deloupe is just as good.
    I do not have experience with the doepker made ones.
  5. Deere hunter
    1,847
    7,734
    Aug 5, 2017
    Shallowater Texas
    Ledwell out of Texarkana also makes a nice one.
    Albertaflatbed Thanks this.
  6. BobO1176
    139
    202
    Oct 29, 2021
    nice, what size gen, probably 10-20kw? Do the hydraulics cycle fast or pretty slow?
  7. Animosus
    Animosus Heavy Load Member
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    Kalyn Siebert or Landoll for recovery work.
  8. Albertaflatbed
    333
    877
    Nov 20, 2022
    Nisku, AB
    I'll take a picture of the setup next time I'm at work. Off the top of my head it's a honda gx20 motor running hydraulics. It's a factory setup.
    Axles slide about the same As when running off of a pto. I wouldn't call it fast perse, but it's reasonable. I can park, run the deck, offload two pickup trucks, reload two more, and be back in position to head down the highway in less than an hour.
  9. Albertaflatbed
    333
    877
    Nov 20, 2022
    Nisku, AB
    Thus is the photos of the setup on the deloupe I am using.
    The two outer boxes are storage, under the center box is the 30 ton winch.
    Magoo1968, BLBurton and BobO1176 Thank this.
