Sleeping in the extreme heat or cold
Discussion in 'Questions To Truckers From The General Public' started by RFENIMORE, Dec 9, 2012.
  1. RFENIMORE
    RFENIMORE Bobtail Member
    8
    Because of today's anti idling law how can you sleep at night when its so hot in the truck? I heard of the APU units battery or generator but what if your truck doen't have one
    do you just sleep in the heat. Me personally i would never fall asleep maybe if it was a new truck it was exempt from this law because of low emissions and you can idle for hours.
    HOW DO YOU GUYS SLEEP IN THE HOT OR COLD WEATHER
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    In winter, many trucks have a "webesto" heater. They burn diesel to create heat that is blown into the cab. More trucks have these then have APU's. APU's are geared more for summertime A/C and electrical maintenance. They incorporate a webasto heater alongside the APU system to supply heat.
    if they don't have a webasto heater, they have to idle.
    RFENIMORE Thanks this.
  4. RFENIMORE
    8
    thank you
    i'm thinking about becoming a tr driver but i'm looking at all the neg first and see if these problem can be solved
  5. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    I use a Bunk warming pad that goes under the fitted sheet and I can sleep comfortable down to 26 degrees with it only halfway up BUT AND I REPEAT BUT waking up and waitin for the truck to warm up is a B&*(C$!!!
  6. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    Everything you see above and if none of that is an option....IDLE THE TRUCK. Dont go to work for a company that either wont let you idle or doesnt provide a APU and or a Bunk Heater....
    American Trucker
  7. Gambinos Wrath
    Gambinos Wrath Light Load Member
    155
    50
    Nov 1, 2011
    Denver, co
    in the middle of summer when I was OTR I was in a volvo where the air con was broken, driving isnt too bad because you can have the windows open, sleeping was bad, I semi ignored the problem as Im used to sleeping in heat, but after only getting 3 hours sleep one night and my eyes burning from sweat pooling in them while I slept I threw a tantrum and refused to drive it until It was fixed
    heyns57 and RFENIMORE Thank this.
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Last summer my condenser on my old employers truck got a hole in it while on a run doing two drops.in Houston. I had a pickup scheduled in Waco back to El Paso the next day and my boss picked up the tab for a motel. Let's just say the drive to Waco and subsequently back to El.Paso in triple digit temps was not pleasant. I didn't have to stop.to urinate hardly at all despite consuming bottle after bottle of Gatorade, lol!
  9. Florida Girl
    Florida Girl Light Load Member
    235
    91
    Jun 20, 2011
    Ocala,Fl.
    hubby's truck will not idel between 20 and 90 and bunk heater does not work co. keeps making excuses about fixing it always this load has to go now, its lkind of hard to sleep when you have to sit up all night hitting the clutch to make truck idle. kind of hard to sleep when you are freezing, is there any rules about this to make his co. fix it. He got real sick the last cold front and now he will be sick again. Thanks
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Any way to put something on the clutch just enough it pushes the switch so it will continue idling? Other than that, obviously the company he is working for doesn't care if (when) either freezing to death or dying in your sleep from the extreme heat will happen. If they think he is out of line for demanding it be fixed or he is quitting, he should tell them to drive their own truck then. I bet this contributes to their overall driver turnover rate significantly.
    Alternatively, there are a few places around the country, one is in Effingham, IL, there is a guy there that reprograms ECMs. For probably $100, he could have the idle limit changed to never shutdown. Mr. Haney could also probably hook you up with this. Just as long as the person changing ECM doesn't call the company to ask permission first.
    RFENIMORE and Florida Girl Thank this.
  11. American-Trucker
    10,371
    5,085
    Nov 8, 2009
    This is exactly why its important to do lots of research before picking a company to work for and why you should avoid big companies like the plauge. Only thing i can think of other then bothing the hello out of his dispatcher about it, have him try parking and releasing the tractor brakes (have him tug on the trailer brake first to make sure they'll hold and IF it works tell him to go into the truck stop and buy a few wheel chocks as a backup just in case.
    American Trucker
    Florida Girl Thanks this.
