I was wondering if i should go with same tool for this type of rivets or other option mounting lights , also whats the best tool to do cut outs , i currently have 2 lights ( one one each side with bulbs ) , would like to add for more to match tractor and trailer .
Sleeper back wall lights
Discussion in 'Ask An Owner Operator' started by pavrom, Oct 28, 2021.
...i cant believe dremel is the best ...i did find punch out - not sure if its worth buying ...my kw becoming more like a toy to me
Are you talking 4” lights? If so the easiest way is a hole saw and then a rubber grommet. Just make sure there aren’t any brackets behind the panel where you want to cut.
You SHOULD have a rivnut setter in your toolbox, but go pneumatic or hydraulic if you plan on anything other than aluminum. Theyre handy.
For cutting small sheet metal cutouts (thin gauge), the tool you want is called a "nibbler", or as suggested above, hole saw for roundpavrom Thanks this. -
feldsforever and pavrom Thank this.
I strive for the first, do okay at the second and much to my shame have extensive experience with the lastbeastr123, Tug Toy, feldsforever and 5 others Thank this. -
feldsforever, Cat sdp, ZVar and 1 other person Thank this.
Had a mechanic one time while prepping a new truck put a self taper right threw a wiring harness in the floor of the truck while installing the fire extinguisher.
The truck had to be towed out of the shop bay to the local Volvo dealer. Turns out the ishift can’t shift with a bolt drilled threw it’s wiring lol
