Slack adjuster
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DL550CAT, Feb 6, 2019.
  1. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,486
    Oct 18, 2009
    Waynesburg, Pa
    So... do you have a preference on the brand of slacks? I have 2 on trailer I just bought that won’t hold adjustment. I’m going to change all 6 (3 axle). I like how the meritors adjust but I’ve heard some negatives about durability. What’s your opinion?
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    I just put all brand new haldex self adjusting on my truck all the way around. Took me a few hours but got it done. That’s what the truck had from the factory. I’ll tell you what. She stops on a dime and holds adjustment. I figured at the same time while everything was apart, I threw in new scam bushings closest to the the slack adjusters and new brake chambers. So maybe that’s why it stops so good.
    Did you check your s cam for play? Slack adjuster won’t work if you have play on the cam shaft which I’m sure you know but just checking
    Also sorry just reread your post. I have no experience with trailer slack adjusters. I run a triaxle dump
    Rideandrepair Thanks this.
  4. 201
    201 Road Train Member
    13,009
    26,844
    Apr 16, 2014
    high plains colorado
    I prefer Levi slacks, but they are so expensive,,,they wear nice,,what? oh, slack adjusters, never mind.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    I just did Haldex also, easy to set up. Been working good.
    First time I ever did it, just watched a few YouTube videos
    DL550CAT and Rideandrepair Thank this.
  6. Troy_
    Troy_ Road Train Member
    1,229
    9,273
    Dec 13, 2017
    Roma, Alberta.
    not a fan of the 7/16" adjuster bolts on the Haldex, they strip easy. the plastic bushings on the adjuster arms wear and break. Gunite are terrible slacks, don't keep adjustment and are also equipped with the easily stripped 7/16" adjuster bolt. only ones that we will use are Meritors. only ever had one get tight and needed to be replaced.
    your mileage may vary.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,594
    6,697
    Aug 26, 2014
    I like the Meritor and Haldex units. All auto slacks have to be set up correctly. Chambers bolts and clevis pins in the correct holes. Chamber rod the correct length.
    The worst enemy to auto slacks is people adjusting them like old manual slacks and racking the gears.
  8. Troy_
    1,229
    9,273
    Dec 13, 2017
    Roma, Alberta.
    that's why I like the Meritors. you have to lift the pawl button to back them off.
    uncleal13 and Rideandrepair Thank this.
  9. xsetra
    xsetra Road Train Member
    5,209
    7,162
    Aug 21, 2011
    I changed all my truck slacks to meritor brand.
    I like the ease of checking and adjusting when needed.
    Don't like gunite,
    Good luck.
  10. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Only time you ever should ratchet the Gears is when it’s time to do brakes. If you have out of adjustment outside of that with these slack adjusters, it’s becuase if worn s cam bushings or bad slack adjuster.
  11. DL550CAT
    1,427
    1,486
    Oct 18, 2009
    Waynesburg, Pa
    You know you’re showing your age. Calling Levis slacks the younger crowd is going “why’s that funny”.
