Slack Adjuster Needs Replacement?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Sep 5, 2019.
  1. PE_T
    PE_T Road Train Member
    I checked the push rod travel on all of my brakes (Type 30; steer type 20). They were all under 2 inches, but one slack adjuster was at 2 inches, and on the same axle, but opposite side I’m getting 1 inch 12/16. I tried self-adjusting them with the brake pedal, but it’s not working.
    2014 Freightliner Cascadia DD15.
  3. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Yes, you need to replace it.
    PE_T Thanks this.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    Gotta adjust them. The bumps and vibration are hell on them.
    speedyk, D.Tibbitt and PE_T Thank this.
  5. AModelCat
    154,242
    I wouldn't point the finger at the slack adjuster quite yet. Auto slacks are dependent on pushrod angle or an external bracket to maintain correct applied stroke. If the brake chambers on the wheels with stroke issues have ever been changed, verify the pushrods were cut to the proper length. Too long or too short will throw off their adjustment.
    pushbroom, stillwurkin, Heavyd and 2 others Thank this.
  6. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    PE_T Thanks this.
  7. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Dont know how my post went intertwined with yours!!?? Must have screwed it up somehow?
    PE_T Thanks this.
  8. speedyk
    speedyk Road Train Member
    1,837
    2,470
    Apr 8, 2015
    When you click Reply it quotes that post, the you can type below. If you just post it doesn't quote.
    Thanks for that video.
    stillwurkin and PE_T Thank this.
  9. PE_T
    See image below.
