Slack adjuster check
Discussion in 'Questions From New Drivers' started by genericsixtynine, Dec 12, 2008.
  1. genericsixtynine
    genericsixtynine Bobtail Member
    Buffalo NY
    Will someone please explain the proper way to check brake adjustment. I have been driving for 9 months, I was doing it one way but was told that was incorrect. :biggrin_25510: That person was a NY state trooper who wrote me a ticket for having 3 out of adjustment.
  3. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    This one is a bag of tricks, at best.
    Auto adjusters, should not be adjusted manually. So they say. Most adjust in one of 2 ways.
    #1 A quick roll in reverse, then apply the brakes. Hard
    #2 Apply the brakes, some auto adjust operate like ratchets. They take the slack out the first time, then you have brakes on the second stab. Never understood that one myself. But I'm no mechanic.
    Manually, I would say the majority of us old school drivers, simply adjust the brakes until they seat against the drum. Then back off a quarter round. Be sure to chock your wheels before you attempt this. You wouldn't want it to roll while you were making this adjustment.
    Disc requirements are different, as some have locking nuts on them. I assume you are referring a drum.
    Of course, that's not completely "correct". As most DOT use a simple gauge to check for even clearance and wear around the drum. Your company, like most. Did not issue you one of these gauges. So it's hit or miss.
    BTW, these adjustments can't be made while the brake is set ;)
  4. Calitrucking
    Calitrucking Bobtail Member
    35
    12
    Nov 15, 2008
    Sacramento,ca
    Slack adjust should have no more than 2 inches of play.
    From the way I was told the legal and rght way is this.
    Park the truck on level ground, chock the wheels.
    Chck how much play the slacks have by having someone step on the brake. If more than two inches then tighten all the way and go back 1/4 turn.
    U need two people for it, but if you could keep the brakes down with a pole then you can do it by yourself with say putting a marking on the slack .
    Hope this makes sense I am typing this from my phone
    Dump 6 axle- 35 Thanks this.
  5. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    The Michigan CDL manual states that "if a slack adjuster moves more than about one inch... it probably needs adjustment."
    The North American Uniform Out of Service Criteria shows the maximum stroke at which brakes must be adjusted. Depending on the design of the brake chamber, measurements vary from 1.25 inches to 2.75 inches.
    If one brake is 1/4 inch or more beyond the readjustment limit, it is a defective brake. If the number of defective brakes is equal or greater than 20% of the brakes on the vehicle or combination, it constitutes a defective brake system.
    If two brakes are at the readjustment limit or less than 1/4 inch beyond the limit, this equals one defective brake.
    When adjusting drum brakes, always tap the drum after backing off the adjustment. If it rings like a bell, the shoes are not dragging. If there is a dull thud, back it off some more.
  6. heyns57
    2,209
    1,011
    Dec 30, 2006
    psanderson Thanks this.
  7. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    That is correct as far as I know. Slack is adjusted with every application of the brakes if the adjuster is working properly. This is if the slack adjusters are automatic, manual ones need adjustment. All need to be checked for proper operation.
  8. im6under
    im6under Heavy Load Member
    782
    406
    Feb 13, 2007
    iowa
    our company manual says the automatics do not adjust from (normal stopping pressure).
    policy now is to apply 80psi of application pressure, while already stopped.
    I suppose they had to add that (while already stopped) for a reason???:biggrin_2552: LOL
    apparently normal stopping pressure is 12-20psi and it just isn't quite enough to keep things adjusted.
    each to his own...
  9. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    That sounds right, but some adjusters do work with very little pressure, if the brakes are wearing fast, that might be a reason. The front brakes have more slack built in as well, and a light application doesn't move them enough to drag at all, also doesn't keep the adjusters working.
    If the slack isn't adjusted by making a heavy non moving application of the brakes, the adjuster is either stuck or faulty.
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    One thing that is very important if you crawl under the truck. TAKE THE KEY WITH YOU. If there's more than one key then take the key and leave a note where you'll know for sure another driver will see it.
    Lilbit and 25(2)+2 Thank this.
  11. 1lownismo
    1lownismo Bobtail Member
    33
    4
    Dec 8, 2008
    Langhorne,Pa
    When I was taught my pretrip I was told I must check my slack adjuster for no more then 1 inch of free play at the pushrod when brakes are engaged...
