Sirius XM radio packaged as CB form?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by SteveBausch, Jun 2, 2017.
  1. SteveBausch
    SteveBausch Light Load Member
    128
    55
    Oct 15, 2014
    Indianapolis, Indiana
    I'd like a satellite radio to install in the Volvo "garage" above my head, I suspect others would like a satellite instead of CB, but not an in-dash installation.
    The Filipino Customer Service agent was clueless regarding CB radios, and the mounting pads in heavy trucks.
    What would the trade terms for this?
    I call it garage, and mounting pad, but nothing pops up on google.
    I'd like to have the CB antenna cable screw onto the satellite radio.
    Any ideas?
  3. SteveBausch
    128
    55
    Oct 15, 2014
    And, of course, I don't know much about this stuff and may be overthinking the situation
  4. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    I am guessing that you want to put an XM/Sirius head unit(tuner) above you instead of using the XM that is already built into your instrument panel AM/FM/XM exisiting radio.
    You can put the XM tuner anywhere, it needs it's own special antenna and wiring, a CB antenna will not work. You need 12V power to it, and I would suggest the direct wired coax adapter that puts the output from the XM tuner directly into the AM/FM antenna input on your existing radio.
    Running all of that from above your head down to instrument panel and hiding the wires will take some doing but not impossible. Depends on how clean you want the installation to look .
    Crutchfield has techs that will understand what you are trying to do, and sell you what you need to do it
    Crutchfield: Car Stereo, Speakers, Home Theater, Pro Audio, 4k TV
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    It's not built to be there. The cb antenna system is totally incompatible with xm radio.
    I'd suggest using it for a cb/weather radio as it's designed.
    We need better communication on the roads other than the middle finger. Hahahahaha
    Cottonmouth85 and msjs91011 Thank this.
  6. SteveBausch
    128
    55
    Oct 15, 2014
    Hmmm.....good ideas
  7. SteveBausch
    128
    55
    Oct 15, 2014
    Amazon.com: SIRIUS XM Radio RG6 COAX Antenna Conversion Kit: Home Audio & Theater
    "This is a complete kit allowing you to use RG6 COAX cable to extend any Sirius or XM Radio antenna for longer cable runs. One connector is used to convert the antenna connection (SMB Jack) into RG6 and the other connector is used to convert back to SMB to plug into the antenna port on the receiver. This is perfect for professional grade SIRIUS XM Satellite Radio installations. For cable runs of over 70 total fee including the antenna cable you will need a satellite radio inline amplifier.
  8. Studebaker Hawk
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    That allows you to extend the cable, does not allow use of the CB radio antenna. The XM/Sirius antenna has more than sufficient wire included to make it from the ideal mounting spot, which by the way is on the roof of the tractor, not on the mirrors. Mirror mounts will work, but not as well as a roof mount. Take a look at all the OEM antenna installations on new cars. All in the center of the roof.
  9. NathanMullin
    NathanMullin Bobtail Member
    38
    8
    Sep 29, 2014
    Vancouver BC Canada
    i went thru this exact situation. and was going to run dual sat antenna until i found this out. first off what year is your truck because if its new enough (mines 2011 670) it will have built in sat radio antennas. the 2 antenna that are on the mirrors are mulit antenna and are cb/tv/sat radio. somewhere behind the dash radio area you will find a yellow square plug that looks like the pic below. that is the sat radio antenna plug. if you have an aftermarket deck that is sat ready you can get the sxv200 vehicle tuner or if you have an external sat radio then this yellow plug will plug into either BUT you will need this Sirius XM Radio FAKRA Antenna Adapter Connector Sirius XM Radio Factory Antenna Adapter: Amazon.ca: Electronics i found the signal way better with the 2 mirror antenna than just the one sat radio antenna. if you wanted to mount the sat radio up top in the cb area then you have to get the sat radio antenna wire extension to run from the yellow plug, up hte a pillar and across to the cb area, then run the audio out back down the deck and plug it into the aux on the radio. alot of work. personally id get a aftermarket deck and sat radio tuner. makes for a much cleaner install. if you have any questions just ask me.
      File size:
      14.2 KB
      42
  10. NathanMullin
    38
    8
    Sep 29, 2014
    Vancouver BC Canada
    the cb antenna are also the sat radio antennas.
  11. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    The duplexer box is a half A approach Volvo used to match a antenna that is not actually resonant on most of the bands it operates.
    brian991219 Thanks this.
