Sirius XM Pro Pack Satellite Radio Kit
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by crazyk, Dec 18, 2014.
  1. crazyk
    crazyk Light Load Member
    98
    47
    Sep 6, 2014
    Northern MN
    Question: Does this work a lot better for some of you OTR than the Satellite Radio Receiver Kit? I'm asking b/c it's $50 more and wanted to know if it's a waste of $ or the way to go since I plan to get SiriusXM.
    Thanks in advance!
  3. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Just go with the regular receiver kit...it works fine. And I found out the expensive way, that my magnetic 'mouse' antenna works just as good as that $70.00 universal mirror mount antenna you find in truck stops...so don't waste your money there either.
    crazyk Thanks this.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,635
    May 10, 2012
    Temple, TX
    I think the Mirror Mount does work better.
    And if you order it of Amazon or someplace like that it's not even close to $70.
    You can buy one of those at Amazon for what Truckstops charge for the 'magnetic mouse' antenna.
    crazyk Thanks this.
  5. crzyjarmans
    crzyjarmans Road Train Member
    3,310
    2,427
    Jun 9, 2010
    Home
    This is true, I've done both, now the tall expensive one sits in cabinet in the buck, using the little mouse one, found a small square metal with a hook on it, with sticky pad on the back side, put that on the roof, and put mouse antenna on that
    crazyk Thanks this.
  6. bobtrucks2204
    bobtrucks2204 Light Load Member
    134
    93
    Jul 23, 2014
    Mechanicsburg, PA
    I may be cheap but I'd call it resourceful.
    Got the regular Sirius and took a piece of cardboard maybe 4" by 6" and folded it into an el. Put the long side into the dash crack up at the window on the pass side, making a platform. Use some elec tape to hold it in place and have the antenna mouse taped on top of that platform. This means everything is inside and portable. Works fine, loses signal just occasionally depending on the direction I'm going
  7. Fourpsi
    Fourpsi Bobtail Member
    11
    4
    Oct 18, 2014
    Sacramento, CA
    How do you connect to the in-cab radio? Is it by tuning to a specific FM channel or works through the aux port?
  8. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    my radio in my new truck came with sirius radio built in
    i dont know or care where the antennae is
    never lose signal
  9. Balakov100
    3,937
    2,635
    May 10, 2012
    Temple, TX
    Best way is if you have an Aux port on the radio.
    FM Channel works as well but not that good.
  10. Lucar
    Lucar Road Train Member
    1,396
    889
    Aug 22, 2012
    Texas
    Remember it's tax deductible
