Single VS Twin turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skinnytrucker79, Sep 17, 2015.
  1. skinnytrucker79
    skinnytrucker79 Light Load Member
    142
    1,601
    Jul 21, 2013
    Wisconsin
    Everything I've driven has had a single turbo . now I'm going in a KW T6 with a 475 twin turbo CAT . just curious what the point of adding a 2nd turbo instead of one big ### one. Do they operate at different rpms? I'm thinking one actuator opens earlier then the other low and high end boost? Just guessing here
  3. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    The twin turbo setup on c15's are called ACERT. The purpose for it is less emission. I don't see difference with rpms. It all depends with ecm file, the way it was built, engine timing, and compression from pistons. acert turbos are not that powerful than the 3406/earlyC15/c16.
    Straight Stacks Thanks this.
  4. heavyhaulerss
    3,723
    2,041
    Dec 23, 2009
    AL/TN BORDER
    the cat twin turbo from 08 to 2011 has a class action lawsuit against it. my friend bought 1 & if it were not for MR. Haney he would of been in a world of hurt, cause he could not give that truck away as beautiful as it looked. cause no one wanted that engine too many problems.
    russtrucker Thanks this.
  5. Hardhat
    Hardhat Bobtail Member
    4
    4
    Sep 17, 2015
  6. Hardhat
    4
    4
    Sep 17, 2015
    Your correct that is how it works. The reason behind this setup is for emissions. You get constant boost at all rpm ranges so the fuel is burnt no matter your rpm's. Black smoke is too much fuel not enough air( aka epa nightmare). The other option was a single vgt turbo. Up until here recently this option was very very troublesome and expensive to replace. Because you cant fix it properly without the proper parts like days of old because manufactuers wont sell the rebuild kits. Crying shame!!!! Twin turbo would be much better if cat could have gotten thier act together n the hardware surrounding it.
    534558 and Straight Stacks Thank this.
  7. rickybobby
    rickybobby Road Train Member
    4,843
    6,719
    Jul 10, 2010
    greensboro, nc
    Mr Haney wrote a good report on the twin turbo. It's on here somewhere
  8. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Based on the Miller Cycle I believe from the 30's/40's. With the ACERT you have VVA's that work similar to a Jake except on the intake side. At the bottom of the intake stroke they open the valve again to get another gulp of air when conditions are met to gain a more efficient burn and less pollutants. Obviously turbo lag is real, not imagined with these engines but they still pull good if driven correctly.
    The 2007 EPA engine were also compound turbo's and like has been said, the base engine was fine....the aftertreatment not so much.
  9. russtrucker
    1,767
    337
    Mar 27, 2012
    Central PA
    and too much sensors.
  10. Cat sdp
    Cat sdp . .
    21,368
    76,797
    Apr 8, 2012
    Orion's Belt
    rank Thanks this.
  11. rank
    rank Road Train Member
    9,907
    113,497
    Feb 11, 2010
    I've heard it said that the are actually not really twin but "sequential" turbos. I think the idea is one spools up quick and then the other takes over.
