Single Round Headlight Adjustment
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GliderKitTrucker, Sep 10, 2021.
  1. GliderKitTrucker
    GliderKitTrucker Light Load Member
    50
    36
    Dec 28, 2019
    I bought a 2000 379 a few months back. Well it came with single round headlights on J brackets. They need to be adjusted down. Anybody on here ever done this with round headlights? Does the nut on the bottom loosen it on the bracket so you can adjust it? I’ve never dealt with these before.
  3. 062
    062 Road Train Member
    6,143
    33,179
    Oct 20, 2013
  4. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    Yes the nut on the bottom you can adjust it ..a 3/4" wrench should be the right size
    Oxbow Thanks this.
  5. GliderKitTrucker
    50
    36
    Dec 28, 2019
    Okay yeah I got it. I appreciate it
    Oxbow and Last Call Thank this.
  6. wore out
    wore out Numbered Classic
    15,340
    185,249
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I use a 3/4 deep socket. My nuts are recessed into the JJ bracket and a wrench won’t help me. Also they have a crush washer around a carriage type bolt that holds all that together. Don’t over tighten or it will take the cushion out of it and cause that piece on bottom to break out around the bolt
  7. GliderKitTrucker
    50
    36
    Dec 28, 2019
    Okay I just snugged them up after adjusting them. But I’ll double check that in the morning. Thanks a lot
    blairandgretchen and Oxbow Thank this.
