Side Skirts and Tails or undercarrage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Aug 24, 2013.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Im specking a new trailer. The KR trailer has the smart truck UT6 Plus undercarrage system. Would I gett better MPG with Aeromax side skirts and a trailer tail? I was under the impression that skirts and tails were the most efficient you could get. Am i incorrect? Are the undercarriage sytems better?
  3. Allan M
    Allan M Medium Load Member
    453
    283
    Apr 20, 2009
    I've got skirts on the Great Dane I pull and honestly think they cost me fuel mileage in high crosswinds.
    Also not sure where to hang my tire chains this winter because they don't angle inward behind the dolly legs like others and can't make alterations until lease is paid off.
    Would personally prefer the UT6 if I'd had the choice.
  4. richardj87
    richardj87 Bobtail Member
    31
    9
    Aug 24, 2013
    dsm Iowa
    We have both in our fleet, talking to the drivers sounds like they make about the same difference. I know the UT6 are virtually indestructible, Ive got pictures on my work computer of a loaded trailer sitting on the undertray (tandems got backed into the ditch) when the wreckers pulled it out of the ditch the undertray popped back out to normal
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I'm running the side skirts. Seeing a steady gain of roughly 0.3 mpg. I would add them to all my trailers if I owned more than one. Can't speak for the under tray system, have no experience there.
  6. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I care about fuel economy more then anything else. I could care less about where to put chains. I also dont back into things or get stuck where it might get damaged.
  7. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Do they gain enough in non crosswind to make up for the crosswind losses?
  8. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    I can't say enough good things about skirts, but haven't tried UT6 or tail to say which is better.
    I've seen gain as high as 1.5mpg but I'd guess avg closer to .5 - .7mpg w/ skirts only.
    Allan M makes good point about hanging chains. <---something to consider
    UT6 has claim of up to 10.5% savings, but don't mention what testing standard they used.
    Transtex Skirt claims 7.4% using EPA SAE type II testing skirt only.
    Transtex Tail claims 6.58% using EPA SAE type II testing tail only
    Transtex combo up to 12% (seems realistic)
    Either way, I'm sure which ever you choose will pay for itself.
    Richter Thanks this.
  9. Allan M
    453
    283
    Apr 20, 2009
    The trailer came with them already installed so I can't answer that question.
    iIt doesn't matter what type of trailer I pull though with my Cat engine the fuel mileage is never great.
  10. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Is it your truck? Get the cat ecm tuned and it will give you better performance and not gulp fuel. I prefer my Detroit to the cat I used to drive tho
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    I was looking at the http://freightwing.com/ aero max skirt because they claim 8.4. I don't know if its true though. As for chains, i throw um under my bunk. I have never actually used um and dont plan to.
