Side skirt dropped down a bit. Cascadia.
Discussion in 'Ask An Owner Operator' started by joseph1853, Oct 10, 2021.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    My Cascadia's drivers side skirt has dropped down a couple of inches compared to the passenger side which is perfect. Is something bent or has it just over time gotten out of adjustment? Is there some way I can get it up a bit?
  3. Snow Hater
    Snow Hater Medium Load Member
    480
    977
    Dec 26, 2019
    You can always try a pill. :rolleyes:
  4. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Couldn't resist could ya. lol. Yeah, I saw that coming.
  5. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
  6. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    Probably a rubber bushing type mount that's chewed up or gone, or bent/broken brackets. Get under it push and tug on it to see what's loose, maybe take the panel off and check the fasteners. The newest Freightliner I had was an '05 Century, so have no idea of your specifics. The KW T600 I had for 8 years, the skirts had rubber bushings on the bottom that fit into a steel channel, then big M!2 or 14 bolts through a fat bushing going in from the side to secure the top. I know I bought one or two each of those bushings during the time I had it.
    gentleroger, LoneRanger and joseph1853 Thank this.
  7. Long FLD
    Long FLD Road Train Member
    11,366
    45,782
    Mar 4, 2015
    If you can move it by hand then something is loose. If you can’t move it by hand then something is bent.
  8. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Check all the brackets. Do you hear anything rattling around?
    joseph1853 Thanks this.
  9. Brettj3876
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Don't know about the FL's but on the macks they had a thin 90 degree piece of metal that would always break off around the bolt holes. Could be something similar
  10. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Must be bent because it's tight. No rattling or movement. That's the first thing I did was grab it and pull it to see if it was loose.
  11. Dave_in_AZ
    369,998
    Pics. Need pics.
  12. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Right. Here's some pic's of both sides. The passenger side looks fine so something to compare to. Frightliner drivers side skirt 1.jpg Frightliner drivers side skirt 2.jpg
    Dave_in_AZ Thanks this.
