Side-exit exhaust questions??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SHC, Mar 20, 2011.
  1. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I have a 2006 387 with a C13. It currenntly has dual rear stacks, which I was thinking of replacing the mufflers on. As I was looking the truck over, I also found a resionator under the cab (I just got the truck, that's why i just found it) and was thinking about just leaving the resinator and doing a 90 degree turn-out with the exhaust exiting between the back of the cab and the rear drives.
    My concern is exhaust fumes in the cab. How many of you have under-cab or side pipes and does it make a big difference? My old FLD has a straight out the top like usual and I could smell the fumes bad inside the truck, and would preffer to not have that. Tho this truck is sealed much better than my old one.
    If not, then I am going to remover the muffler under the cab, and go with the Pittsburg high-flow mufflers (my brackets are for a 11" wide muffler, so Donaldson won't work) and this is why I was thinking of going with the side exit as it would be much cheaper than the $300 for the new mufflers.
  3. CBtalker205
    CBtalker205 Light Load Member
    134
    64
    Oct 30, 2008
    Pittsburgh, Pa
    legal wise I dont think there is any concern. Except for cali of course. One of our company trucks has the yard burners on it and not a DOT one has said anything about it. There is a fast build up of exhaust soot on the front drives though.
    In fact its the truck in my avitar. Didnt realize that.
  4. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Are you going to idle at the ol' truckstop? If so, consider this... your exhaust will be coming out right into the sleeper of the truck next to you.
    So how do you feel about giving other drivers carbon monoxide poisoning in their sleep?
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    I spent over a year in a day cab with a grass burner. Most of the time it wasn't a problem, but I got enough exhaust from it to know that I sure wouldn't want it with a sleeper.
  6. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Well in that case.... I'm all for him converting his truck into a grass burner. In fact, I think I'll convert mine as well.
  7. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Just run it up into YOUR cab, eh? :biggrin_2559:
  8. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    This is actually kind of why I got rid of the straight 8" on my FLD..... I would refuse to park next to a truck to idle as it was loud as hell and I didn't want to keep anyone awake. I'd always park with the stack facing an open field or try to park on an end. Not only was I worried about myself, but also other drivers. I guess I will just dump the cash on some new mufflers.
    So i guess my next question is, what is the purpose of the extra muffler under the cab? Is it just for sound deadening? I may just remove it and replace the stack mufflers then, as I see no need for 3 #### mufflers. I'm sure it doesn't help with my MPG either having all that restriction
    IH Truck Guy Thanks this.
