Should you have new drive tires balanced??
Discussion in 'Ask An Owner Operator' started by dashaker, Aug 5, 2021.
  1. dashaker
    dashaker Light Load Member
    54
    12
    Aug 7, 2014
    When buying all 8 brand new drive tires I was wondering do any o/o on here have them balance before putting them on the truck?
  3. willisl64
    willisl64 Light Load Member
    77
    115
    Jul 12, 2014
  4. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    Yes, I do. Could have an out of balance wheel. It’s not just for the tire.
    Regardless even if brand new I would balance but that’s just me. Gotta protect your investment.
    Im that guy that does shocks and an alignment each time I do tires though. lol ;)
  5. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    Let me ask you this
    Do you balance new tires on your car...??
    Team818, dashaker and Jarhed1964 Thank this.
  6. woolybully35us
    woolybully35us Medium Load Member
    313
    550
    Mar 13, 2015
    ks
  7. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    From you posts i understand you run just new trucks . ... I guess depends what brand tire you put on . If you put michelins or similar brand you need replace shocks more often than once in 300-350k miles :)
    I have seen oem shocks leaking sometimes as soon as 20k miles , most of the guys i talk replace at 100-120k or once a year
    flood and Midwest Trucker Thank this.
  8. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    Simpler and probably cheaper to just put a set of drive position Centramatics on.
  9. Midwest Trucker
    5,871
    21,124
    Aug 31, 2018
    Right, yes on new and they are Bridgestone. Fronts go at 150k and it gets new front shocks and 3 axle alignment. At 250k the rears get replaced, new rear shocks, and another 3 axle. I’ve been happy with the Bridgestones so mostly stick with them. I did 1 set of Michelin’s so we’ll see how they work out.
    Maybe I should do rear shocks when I do the front shocks too. It’s just what I’ve been doing.
    Vampire and Speed_Drums Thank this.
  10. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    Not spin balanced, unless you spend 6 hours every day picking rocks. Throw in balance beads.
    Spin balancing only accounts for the wheel and tire. What about the hub and drum? Balance beads also change as the tire wears. Spin balancing is only effective at the wear point where the tire is when balanced.
  11. pavrom
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    I have 260k on my good year drives and thinking another 50k or more should be no problem , i would like to replace them with michelins after hoping to have even more of them .
    Vampire and Midwest Trucker Thank this.
