should i rebuild a 2ws 3406e or change to a 6nz c15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mikepdw, Mar 15, 2015.
  1. mikepdw
    mikepdw Bobtail Member
    7
    I have a cat 3406e 2ws that spun a rod bearing should i switch to a 6nz c15 or have my 2ws 3406e rebuilt
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    There both great serial #s. It all depends if your crank is bad in the 2ws. Also depends on how much is going to cost you for a 6nz. Also the labor to re&re engine. Find out if crank is ok first.
    If it's good rebuild the 2ws. If not and you got a line on a good 6nz giver.
  4. mikepdw
    7
    We did bad marks on crank #6 and the rod is messed up
  5. mikepdw
    7
    Found a 6nz running take out with 300000 on complete rebuild for 12000 with paperwork 550hp and and they dont need a core
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Mmmmm tuff call, but if indeed crank is messed up its probley going to be cheaper and faster to just drop the 6nz in there. You got to think of down time too.
    This way you got the 2ws with a lot of good parts left over. It will all interchange with the 6nz.
  7. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
    2WS is a 40 pin, 6NZ 70 pin if Im not mistaken.
  8. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Your mistaken. Both 70 pin
    Diesel Dave Thanks this.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    Weren't the 2ws motors notorious for snapping crankshafts though?
  10. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
  11. mikepdw
    7
    The 2ws only has 449000 original miles just baught in in Kansas Drove it back dropped a valve in #6 cylinder only 250 miles from where we got it .had it towed to western colorado back to our shop.had a mechanic put a reman head from cat in it bearings, and cylinder pack ,this was all in hole #6 rest of the holes looked great . so we decided to clean it the best he could and fix the one hole that was messed up and and put new bearings in. the only thing that we can think of that he did not get all the broken up piston and metal out and there was some still left in the crank. The mechanic was nice and felt bad about it and didnt charge us for the the labor or the cylinder pack .we baught the new head ourself and it is still good. Kinda dont know if its something wrong with the engine its self cuz we keep having trouble with that #6 hole. We do have a good rebuildable core with a good crank in it and the new head left. As far as down time we are a construction company that baught the truck for our heavy haul we still have our old heavy haul tractor we can use untill we get it fixed
