Should i get an alignment?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Allan Decker, Oct 9, 2013.
  1. Allan Decker
    Allan Decker Bobtail Member
    43
    21
    Nov 19, 2009
    montz, la
    Just had torque bars on rear axles replaced, and drag link also. Do I need an alignment now?
    Thanks in advance
  3. Off-n-on
    Off-n-on Light Load Member
    156
    80
    Aug 4, 2013
    Phila, PA
    Aside from you and me there are tons of people in this industry that need their heads realigned
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    It depends on the type of torque bars. If you had just transverse ones done, they are perpendicular to the frame rails, they do not affect the alignments very much. The drag link only affects the steering linkage between the gear and steering arm. It has nothing to do with any steer axle alignment settings. The old drag link would make the steering sloppy. The only thing a new drag link can change is how the steering wheel is centered. Technically you do not need an alignment. If your tires are wearing nicely I would leave well-enough alone. If it has been more than two years since your last alignment and you want to cover all your bases, now would be a good time.
    Allan Decker Thanks this.
  5. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    Alignments are relatively inexpensive, unless you just had one done why not do it. Much cheaper than a set of steer tires.
  6. landstar8891
    landstar8891 Road Train Member
    2,414
    2,310
    Feb 4, 2012
    NY NY
    I would not hesitate one second.Get the alignment done and stop being a cheapo..I just had alot of front end work done and the whole rear end worked on.I tryed real hard to ''pinch the penny''.My machanic had to YELL AT ME to get this cheap job done..
    Alignment was 150.00.Steers would be around 5-6 hundred a peice.I learned alot about this alignment and i will be in every 6 months to get it adjusted.These COW TRAILS we ride on will kill the steers and alignment..
    I learned my lesson after the last 2 sets of steers and getting alignments done..Never Again,i hope....
  7. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Alignment every 6 month?????
    Real Deal Thanks this.
  8. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    no, don't do an alignment, put new tires on it constantly ,
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The torque arms for the rear alignment, latterally, are part of the rear alignment, set with shims. You can check that with a tape measure, from the edge of the tire rim, look down the inside of the frame rail, measure both sides, it should be the same.
    The other torgue arms, are for setting the the angles of the rear ends, set with shims. That should have been checked when they replaced the torque arms, 90% of the torque arm bushings are replaceable, you do not need to replace the tube.
    The drag link does not change the alignment, in any way possibly the steering wheel position will move, and that is very rare.
    Just a thought!
  10. Allan Decker
    43
    21
    Nov 19, 2009
    montz, la
    Thanks for all the advice, its greatly appreciated. I routinely have my truck aligned, and I'm not a cheap ###. I put more money into my truck then my own pocket lots of times. Just wondering if it was a must do right away. Btw its the torque bars that are parallel with the rear ends
    Surprised by the amount of smart ##### on this site though..
    The Challenger Thanks this.
  11. sinnano7
    sinnano7 Bobtail Member
    11
    Oct 10, 2013
    id,say.no.youll,be,fine,do,it,all,the,time
