I am 5ft tall bout 130lbs. I am a very safe and cautious driver and would never attempt to drive if i felt i couldnt reach my pedals or shift or see properly, but making this work has proved to be a bit of a challenge. i didnt fit the new kw well at all, and had to use multiple hard pillows to make my back and rear reach the back of the seat. lumbar support was shot to accomidate my size. and i have nothing to really support my upper back at all - it causes alot of unnessesary fatigue. -i have sense moved into an older freightliner that has a shorter seat bottom and i can max out the 2 lumbar adjustments and it works alright for my size... i have to admit though, im not very comfortable. I wish i could figure out something better. i tried one of the pillows with armwrests from walmart it was nice but short, and i have half my mind to rip off the back of a kids carseat, but the cheap ones dont actually come appart ( yes i looked lol), i have also considered trying to some how cut a front sliver off a truck seat that someone has disgarded and somehow install it infront of the existing one... i just want a couple more inches to push back against so i dont have to have my elbows and knees so close to the wheel. its a pain in the butt. i dont expect the trucks to be made for my size, but im wondering if anyone else has had to do these weird pillow cushion adaptations etc, to fit the seat? i mean ive seen other short drivers so i cant be the only one with this issue... what have other people done? this is a bit silly - i suppose i could get one of those fancy advertized custom seats one day when im an o/o, but thats a bit far off yet....has anyone bought the custom seats? is it worth the price, etc?
thanks so much
Jane S.
Short Person Problems...
Discussion in 'Questions From New Drivers' started by Jane_Smith, May 16, 2015.
CK. for hard seat covers made to help people with bad backs,they are like a seat cush. that you can place things behind them to be closer to steering wheel but still sits like a car seat?
I know a team who has one very short (4' 9") person driving the truck, she had made pedal extensions to operate the truck because any adjusting of the seat would put her mirror view in jeopardy and could cause an accident.
I don't know how it was done other than the first set was clamped onto the pedals and made of wood to see if it would work, they had sheet rubber glued to both ends of it to prevent it from slipping. -
I don't know about comfort, but since you mentioned car seats, my son has a high back booster seat by graco, and the back of that detaches to go to a normal booster...
baha and Toomanybikes Thank this. -
You can get memory foam in smaller-than-full-bed sizes at kraft places like Michaels, Hobby Lobby, etc.
Also available in different thicknesses.
Mikeeee -
There was a woman driver at the bus company where I worked, she could not get the seat adjusted in the new MCI buses that came in to replace older Gillig models. She refused to drive because she said it wasn't safe, even though management disagreed with her. They disciplined her, she reported them to the Federal Transit Authority, they came in and agreed with her that it was not safe. But nothing was ever done about it to accommodate her, and she ended up leaving on her own not long after that.
With a truck, at least you could do things like extend the pedals. With the bus, she had to be able to drive any bus in the fleet, not just one bus for her.Toomanybikes Thanks this. -
I know what you mean, the truck my wife loved almost required 911 to get me out after driving 600 miles. I will look into hard seat covers and yes I carry small pillows when I travel in some vehicles. I worked at a company with a short guy that bolted 2x4's on top of the pedals and his clutch was adjusted a little different. A good upholstery shop could probably recover the seat back with extra foam for a 150 bucks or so. Custom seats are surely expensive and I have no experience with them. If you are a very safe cautious dependable operator you are a large asset to any company you choose to work for regardless of your physical size. While you or the company may not be able to justify the cost of a custom seat ask for assistance. With a little experimenting with pedal heights ( they may not all be the same) , seat backs, bottoms, and tiltwheels (if available), you and your company should be comfortable.
Jane_Smith Thanks this. -
I found cushions made of memory foam at Wal Mart that I use for back support outside of the truck. These cushions are intended for wooden kitchen chair bottoms. They are however, when used on your back and not your butt, tall enough to probably work. The cushions are about 1 inch thick, so you can use one or more cushions to give you the thickness behind your back that makes you comfortable. Being memory foam they are study enough to not wear out or squeeze down quickly.
You can probably make something cheaper by getting a memory foam sleeping pad from Wal Mart's camping section. Buy one 6 foot long sleeping pad, and cut it into the proper shape and one full-size sleeping pad can be cut into the proper shape for use behind your back, and the long length of the pad equals several layers of thickness, depending on how many you stack. Make a stack and put the stack into a pillow case. -
Just recalled short guy also had a board bolted to floor behind throttle pedal and a fold out step bolted to left kick panel
