Shock Absorbers
Discussion in 'Freightliner Forum' started by OneTwentyOne, Jun 25, 2017.
  1. OneTwentyOne
    OneTwentyOne Light Load Member
    76
    22
    May 19, 2016
    Good day to all.
    I know this will bring about many inputs, but I have no history data on the shock absorbers on my 2010 Cascadia. I have cupping on the drives and have heard, read and been given advise on the reason for the cupping - the shock absorbers.
    A little info on the truck and wheels: I purchased and installed CENTRAMATIC on all three axles - this improved and almost eliminated all the shaking. I have brand new Goodyear steers,less than 5K miles on them. I had a three axle alignment performed.
    The 2nd and 3rd axle tires have plenty of meat on them, however, they appear to have mixed and matched Goodyear's (same model); when I purchased the truck.
    I am torn on whether or not to have the drive tires cut for obvious reason - reduction in life. However, do want to eliminate the cupping.
    So, which shock absorbers do you guys suggest are worth the bang for the buck, and let me hear your thoughts on cutting / rounding the tires? My loads are normally HEAVY loads (40-45K) - in the event this matters.
    thanks,
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I just buy the Monroe shock from Fleet pride, nothing special
  4. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    freightliner have oem shocks at dealerships. twice expensive than Monroe. its worth to have them on truck.
    Rideandrepair and TAfool Thank this.
  5. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    Replaced mine with Gabriel fleet line. Three of them blew-out within 2 months. Replaced them with Monroe's. Those lasted two weeks before they started blowing out.
    Replaced them all with factory shocks and have no problems with them since. They are easily twice the price of aftermarket but we'll worth it.
    TA
  6. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    The tires reverse direction. Shock brand am open .
  7. FreightSheikh
    FreightSheikh Bobtail Member
    5
    My Freightliner guy told me go with nothing but Gabriel 85724 shocks.
  8. OneTwentyOne
    76
    22
    May 19, 2016
    I was speaking with a Freightliner Tech that worked at an Elite Freightliner and this is what he said, "Sachs manufactures the shock absorbers for OE Freightliner. The reason the OE shock differs from regular Sachs shock absorbers[price is that Freightliner slaps on their OE part number on it, but there is no difference in the regular Sachs shock absorber" - which is substantially cheaper. Any thoughts on this comment from one of thier techs?
    Rideandrepair and shatteredsquare Thank this.
  9. brysol01
    brysol01 Medium Load Member
    312
    445
    Nov 2, 2009
    would ya please share what your freightliner guy recommends for the front shock, my Cascadia
    is terrible, blew the Monroes shortly after installation, there is a fleet line number, but no upgrade to SLX
    shatteredsquare Thanks this.
  10. Rideandrepair
    17,202
    55,795
    Aug 8, 2015
    I’ve been told a few times Freightliner orig made by Gabriel. Monroe although has thicker piston aren’t as good. Just changed mine a few months ago with Monroe although I knew better already riding worse absolutely last time for Monroe’s. I get original at Stoops on sale occasionally.
  11. Iceman1643
    Iceman1643 Light Load Member
    82
    115
    Dec 29, 2023
    Bmore MD
    Any thoughts on the brand Bulldog? 4States says is a worthy OE replacement with alot of upgrades to the shock design.
    But that could just be Salesmans Snake Oil
