Shifting Eaton 7 Speed - Speed for Gears
Discussion in 'Questions From New Drivers' started by FreightlinerGuy, Jul 16, 2013.
  1. FreightlinerGuy
    FreightlinerGuy Medium Load Member
    472
    225
    Apr 20, 2008
    Great Lakes, USA
    Hey all,
    I'm curious of the speeds for a Eaton 7 speed.
    I'm talking about the trick used like 35 = 8th gear, 45 = 9th, etc..
    Would 5th be about 35 mph or?
    Thanks
    PS: there is no hi/lo, just straight 7.
  3. TripleSix
    127,950
    Sounds like you're driving a 24 ft rental truck...been eons since I've driven one of those. That's worse than driving the old spring ride cab overs with Armstrong steering.
    Anyways, are you asking at what road speed do you shift? Don't worry about the MPH, do it by the rpm.
  4. FreightlinerGuy
    472
    225
    Apr 20, 2008
    Great Lakes, USA
    Yeah, I'm asking at what road speed to shift, downshift really. I know 1700rpm is the 'sweet' spot, but still curious at what rpm/road speed to downshift.
  5. Sailorguy
    Sailorguy Bobtail Member
    9
    Jul 16, 2013
    Bethany Ontario
    Only matters if you own it :)
  6. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    My current truck is a 7 speed. Most up shifts are done at around 1800 rpm and down shifts are around a grand. I don't watch mph with it like I did my 10 speed. The 8th at 35 stuff won't work with it.
    Rear gears make a huge difference with a 7.
  7. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    There is no way to answer this without knowing tire size (preferably revolutions per mile) and rear end ratio. Once you know that it simple match based on the ratios of your trans. Also depends on rpm.
