Shifting at a red light
Discussion in 'Questions From New Drivers' started by jdr1989, Apr 13, 2013.
  1. jdr1989
    jdr1989 Light Load Member
    147
    63
    Apr 13, 2013
    ok my problem is ill be going down the road in 10th and a light will turn red so ill start down shifting I get to 7th and then slow down a lot to stop but then it turns green and I always grind every gear trying to find which one to put it in how can I stop this. and also what do I when this happens going up steep hills and there's redlights at top and bottom of hill please help
  3. vinsanity
    vinsanity Road Train Member
    1,760
    689
    Nov 23, 2009
    South Florida
    Look at your speed. That will determine what gear you should be in. Then bring your rpm's up to where they should be to put it in that gear. Don"t panic and don't just start revving it up and trying every gear.
    davetiow and LaBubba Thank this.
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    pay attention to your road speed and learn when to shift THAT WAY too.
    CondoCruiser and LaBubba Thank this.
  5. Knucklehead
    Knucklehead Road Train Member
    1,977
    24,664
    Jan 21, 2006
    You're supposed to continue to downshift as you slow down; not downshift once, then just brake to stop. Then, once the light turns green, you're already in the correct gear to take off again.
    Pmracing Thanks this.
  6. Fester69
    Fester69 Light Load Member
    208
    110
    Oct 19, 2012
    Omaha, NE
    At the company Im with they have us skip a we shift down. At school I learned to hit every gear on the way down. With my 10 speed now I slow to 30 and go into 7th, then 15 and get 5th, then 2nd right before you stop. I lik it much better, and Im always in gear if a light turns.
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    if you are not in gear and just rolling in nuetral you are not in control of your truck
    if you need to make yourself a note with what speeds to be in what gear and paste it to the dashboard
    eventually you will just hear the engine and will be second nature
    LaBubba and BrianE Thank this.
  8. rockee
    rockee Road Train Member
    1,393
    673
    Apr 17, 2007
    Pacific Northwest
    Maybe part of the problem is you are coming up to the light so fast and then have to play catch up when it turns. If you know the light is red slow down gradually so you don't have to come to a complete stop. Not bashing you cuz I don't know but you ever notice how many people race up to the stop light/sign? Whats up with that? You don't have to down shift every gear and you don't have to skip just two gears. It's all gonna depend on traffic in front of you and your speed. Try braking and going from 10th to 6th or 5th but like was mentioned, learn what gear to be in for your road speed and approx. where the rpm's should be.
  9. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    You need to learn what gear is relevent at what road speed and engine speed. Write them down to begin with and stick it on the dash and dedicate yourself to learn them. A quick look at the speedo and the RPM and you should know what gear to select. Many years ago my old trainer told me there are two possible gears for every road speed, one at 1100rpm and the other at 1600rpm. Every truck is different because of gearing, type of transmission etc but the theory is right.
    Plan B. Drive an automatic.
    LaBubba, CondoCruiser and davetiow Thank this.
  10. Dryver
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    deleted duplicate post
  11. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    smith system-get the big picture..observe lights tht are stale(one color for an extended period of time), chances are its going to change soon..So start easing ouf of the throttle and prepare to slow down.
    road_runner Thanks this.
